Old 09-19-2024, 11:54 AM #1
mendozer mendozer is offline
mendozer is on a distinguished road
Full bushing swap for suspension
Anyone every swap out the ENTIRE bushing setup with those Energy Suspension kits. Seems pricey at 670 bucks and I wonder how many of those bushings really matter.
I obviously want to change sway end link bushings, control arm bushings, but do I need the body ones? Bump stops would be nice sure.
this is the kit I'm referring to
Attention Required! | Cloudflare
includes these:
Front Control Arm Bushings - 8.3132
Front Bump Stop Set - 8.9103
Front Sway Bar Bushings Set - 26mm - 8.5141
Body Mount Bushings - 8.4110
Steering Rack Bushings - 8.10103
Rear Control Arm Bushings - 8.3133
Rear Bump Stop Set - 8.9104
Rear Shock Bushings - 8.8102
Rear Sway Bar Bushings Set - 14mm - 8.5142
Rear Track Bar Bushings - 8.7106
mendozer is offline   Reply With QuoteReply With Quote
Old 09-19-2024, 04:21 PM #2
96RedRunner's Avatar
Real Name: Mark
96RedRunner is a splendid one to behold 96RedRunner is a splendid one to behold 96RedRunner is a splendid one to behold 96RedRunner is a splendid one to behold 96RedRunner is a splendid one to behold 96RedRunner is a splendid one to behold
Real Name: Mark
ES for control arm/link bushings not a route I'd go better choices out there.
96RedRunner limited 4x4 5VZ auto not stock 374k miles totaled 2018.
2001 limited 4x4 5VZ auto work in progress not stock.
2011 Audi S5 Prestige 4.2 V8 6 spd. MT not stock.
Old 09-19-2024, 05:06 PM #3
like what? I was under the impression PU > rubber in terms of suspension quality/sway/steering.
Old 09-19-2024, 05:48 PM #4
GhostRing's Avatar
GhostRing GhostRing is offline
GhostRing has a spectacular aura about GhostRing has a spectacular aura about GhostRing has a spectacular aura about
GhostRing's Avatar
His posts usually need a bit of "interpreting"... ;)
I assume he is referring to using Whiteline Bushings for the A arms and rear linkage.
The A arms in particular are easier to install compared to the ES version.
I went this route about 3 yrs. ago - and while they have been quiet, the rears are starting to wallow out.
I do wheel the vehicle proper, so that is quite likely the cause of the accelerated wear. YMMV
Build Etc...
If it ain't broke, fix it 'til it is.
GhostRing is offline   Reply With QuoteReply With Quote
Old 09-19-2024, 05:52 PM #5
oof those are pricey bushings. i just looked up up 289 for a single control arm bushing.
Old 09-19-2024, 09:57 PM #6
Zhehan Zhehan is offline
Zhehan has a spectacular aura about Zhehan has a spectacular aura about Zhehan has a spectacular aura about
Here's the Whiteline bushings for your vehicle. Products
– tagged "1997-toyota-4runner-base-esi7167975" – Whiteline USA
I'd go with Whiteline before ES, and I did. I have a mish-mash on my truck. But, ES < Whiteline
2000 4Runner SR5 Manual Trans Federal Emissions - Eibach Pro-Truck coilovers, LC 7.5/Tokico Black, JBA UCA, SPC 25945 RLLs, Mevotech Supreme RULs, TrakMotive Xtended Travel CV Axles TO-8043ET, South Bend Rally Clutch, ES & Whiteline Bushings, MagnaFlow Cat-Back, Deck-Plate Mod, 4.56 Yukon Gears, Yukon Grizzly Rear Locker, Bushwacker Flares, 16x8 Wheels w/ 285/75 General Grabber AT2, 229K+ Miles
Zhehan is offline   Reply With QuoteReply With Quote
Old 09-20-2024, 01:42 AM #7
interesting whiteline shows the rear as 17mm. i've seen 19mm for the rears elsewhere.
I think for now I'll just do sway bar bushings. New end links will be done too. Those are the only ones I'll do for now
Old 09-20-2024, 06:42 PM #8
Real Name: Mark
Real Name: Mark
lighten up, got @mendozer to ask his question. Conversation continuation.
@mendozer I use OE LCA's, Whiteline UCA Rear Links, ES Rack S/B's Body. YMMV.
4 yrs dual lockers "don't use em lose em" works for me, for now.
ES last I'd use for LCA's
Old 09-20-2024, 07:38 PM #9
Why the mixture? Did you find some brands bushings just lasting longer for those specific applications? like why not whiteline for all if ES is inferior?
also I don't understand the "4 yrs dual lockers "don't use em lose em" works for me, for now" comment. Are you saying that by not using the lockers you ruin the bushings?
Old 09-22-2024, 11:10 PM #10
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
I'd definitely go with Whiteline over Energy Suspension for the Front Lower Control Arms. I'd also use Whiteline for the Rear Upper and Lower Control Arms.
Energy Suspension is good for the Steering Rack and Sway Bar Bushings.
@infamousRNR and I have videos for all these bushing swaps on our Timmy the Toolman YouTube Channel. Just do a search on our channel and you'll find what you're looking for.
Timmy The Toolman - YouTube
Old 09-22-2024, 11:14 PM #11
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Energy Suspension isn't remotely comparable to Whiteline for the front lower control arms. Whiteline mimics the OEM design providing a metal sleeve that encases the poly bushings. Energy Suspension requires you to burn out your old rubber bushings and use the OEM sleeves. ES sucks because of that. Whiteline is way more plug and play and they also last.
Old 09-23-2024, 02:26 AM #12
Real Name: Mark
Real Name: Mark
I tried ES LCA bushings 09-10 not inclined to do it again, W/L come along since figured
others would chime in with whiteline exp. red flag ES this area.
OE v PU some tradeoffs your choice I might experiment again. Later.
OE Rear link options limited W/L>ES 12k+- mi look good.
ES least critical easy to change stuff. $.00002
Comes from OE locker quirk, effort and expense lockers not meant to sit there and look pretty.
My mix 4 yrs of dual locker use/abuse no failures YMMV.
Old 09-23-2024, 04:08 AM #13
Real Name: Mark
Real Name: Mark
You owe me laptop spit beer on mine laughing, you ain't lying. Is a back story to that.
Old 09-23-2024, 12:06 PM #14
The last time I bought ES R&P bushings, the D shaped bushing was WAY too soft and you could see the rack move up and down when you turned the steering wheel. I replaced that piece with the part from the Whiteline kit and the problem was solved. Much firmer durometer bushing.
I have Whiteline LCA bushings and they were a perfect fit.
Old 09-23-2024, 02:42 PM #15
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
Poly is more maintenance intensive. Ideally you need to disassemble and regrease annually - but good for you if you are that motivated. I also use Energy Suspension grease on all my Whiteline bushings. It is silicone based and resists washout longer than Whiteline's moly grease.
Not impressed with ES aside from their steering rack bushings. But I do have a minor clunk on my passenger side so I will now inspect the D shape bushing. I have Whiteline upper and lower bushings up front. Install sucked but by far the most worthwhile reward. ALSO, I spray the crap out of my frame with Fluid Film and notice that it stops my bushings from squeaking. We'll see how long I can get by with that shortcut. I'm doing the full Whiteline treatment on all my rear bushings soon too. They make quality products.
arm , bushing , bushings , suspension , swap
How easy is a bushing swap on my UCAs?! LOSTR4 4th Gen T4Rs 9 01-30-2020 06:51 PM
Suspension Bushing Replacement hallcs 3rd gen T4Rs 3 07-13-2017 06:04 AM
Front suspension upgrade - LCA bushing swap, Bilstein 6112 alia176 4th Gen T4Rs 10 06-24-2017 04:39 PM
Have you ran a full taco suspension swap only? Cygan1008 4th Gen T4Rs 77 05-09-2016 10:59 PM
Question About End Link Bushing Swap RPC 4th Gen T4Rs 6 06-03-2014 11:50 PM
