Old 09-24-2024, 02:31 PM #1
eternalize eternalize is offline
eternalize is on a distinguished road
Angry 3rd Gen Transmission Limp Mode (99' A340F) No Codes
1999 limited 4Runner, 3.4L w/ 230,xxx miles :: I'm at a loss of words when the shop I left my beloved at in Hailey Idaho says after minimal testing that it is just a mechanical problem without explaining much in their writeup.
Previous Symptoms: no whirring, clunking or loud sounds coming from shifting, (day of problem) went through tons of puddles wheeling, immediately washed the undercarriage and engine bay clean, drove for around 1.5 hrs at 70mph no problem, parked, then started her up and won't get out of this limp gear, no check engine light or throwing any codes
Symptoms Now:
starts and won't shift out of 3rd gear? (reaches around 30mph at ~3,000 rpm)
goes into reverse fine
transfercase works fine all throughout in 4 high, low and the 4wd button
no check engine light code (or code history after getting it read in the shop)
transmission filter is original since new I believe (pink manufacture gasket maker is what the shop said)
checked all 3 solenoids after dropping the tranny pan and they read ~9-11 ohms each
after asking the shop, they said they checked the wires going to the solenoids for (was it voltage or resistance?) and they said it was fine, but didn't do a writeup on it?
after dropped pan, no shavings, only small buildup on magnets, and no milkshake
Possible next steps:
  • Pay $$$ for the shop to disconnect some type of harness to the transmission to manual shift into gears? Forget what its called, but the harness on the outside of the tranny to manually shift it into L, 2, and D?
  • Check the ECU that it's sending correct signal down to the solenoids?
  • Torque Converter problem? Not sure why this would be the case?
  • Replace the transmission :/
Most frustrating thing is that everything was fine up until leading up to it and there is no blaring red light on something specific indicating failure. I'm debating on sending the $300 to fly down back to Idaho to test this myself with my multimeter on a dirt lot. Any help for my daily anyone?
eternalize is offline   Reply With QuoteReply With Quote
Old 09-25-2024, 09:02 AM #2
jgue467's Avatar
jgue467 jgue467 is offline
jgue467 is a glorious beacon of light jgue467 is a glorious beacon of light jgue467 is a glorious beacon of light jgue467 is a glorious beacon of light jgue467 is a glorious beacon of light
jgue467's Avatar
Could be mechanical or electrical - the FSM has complete diagnostic tests to run - here's a couple excerpts.
3rd Gen Transmission Limp Mode (99' A340F) No Codes-trans-2-jpg  3rd Gen Transmission Limp Mode (99' A340F) No Codes-trans-1-jpg
2001 Limited 4WD - 350+K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL - StopTech ANGLED rotors - In series 699 trans cooler, New Yota1 transmission, All new OEM suspension front to rear.
check , fine , problem , shop , transmission
3rd gen Limp mode? MandAtaco 3rd gen T4Rs 7 03-07-2023 12:15 AM
T4R went into “Limp Mode” Saker 5th gen T4Rs 77 09-13-2021 12:35 PM
Limp Mode P2138 Chilow 5th gen T4Rs 11 01-06-2021 01:43 AM
Limp mode for the blink of an eye. Monty87ls 4th Gen T4Rs 1 10-19-2020 03:30 AM
22re limp mode theking11863 Classic T4Rs 3 12-12-2019 08:57 PM
