Old 09-28-2024, 07:48 PM #1
Forrest931 Forrest931 is offline
Real Name: Forrest
Forrest931 is on a distinguished road
Real Name: Forrest
Another 3rd gen wih a mystery Clunk.
First, here is some backstory on my car, I have a 1998 4runner Limited 284k miles billstien 6112 5160 lift. a couple of months ago I started hearing some metal-on-metal sounding clunk from what seems like the front suspension. It started pretty quiet and after lifting my car, it seemed to become louder and louder. It's generally when the suspension is articulating at lower speeds IE speedbumps and potholes. I do think its louder when the weel is turned and I hit a pothole.
I got under my car and wiggled around the tie rod and it was making a loud clunking noise, I thought I found it and did the inner and outer tie rods and got an alignment. this did not fix my problem so I then Did lower ball joints and sway bar end links. As well as getting under my car and torquing every bolt I could see down to spec.
It seemed to quiet down for another few days but now it's back in full effect. there are a lot of things it could still be I've found a little play in my driver-side CV and my sway bar bushings are old and blown as well so that's my plan as of right now.
If anyone has an idea that can solve my several month-long battle I will mail a case of beer your way. It sounds like someone taking a dead blow to my frame and it doesn't inspire a lot of confidence in things like long road trips and 4 wheeling.
To Reiterate the things I have done in the past year
Sway bar end links (China w/ poly bushings)
Lower ball Joints (OEM)
Front shocks (6112's)
Rear shocks(5160's)
Inner tie rods (Moog)
Outer tie rods (Moog)
Diff drop (total Chaos)
Thanks!
Forrest931 is offline   Reply With QuoteReply With Quote
Old 09-29-2024, 12:16 PM #2
Zhehan Zhehan is offline
Zhehan has a spectacular aura about Zhehan has a spectacular aura about Zhehan has a spectacular aura about
Check the Upper Ball joints. Disconnect the spindle from the UCA and check them for play. If you've never replaced them just do it. Or, get a set of aftermarket UCAs like the JBA or SPC to help with articulation, better alignment and added Caster for way better handling.
My .02
2000 4Runner SR5 Manual Trans Federal Emissions - Eibach Pro-Truck coilovers, LC 7.5/Tokico Black, JBA UCA, SPC 25945 RLLs, Mevotech Supreme RULs, TrakMotive Xtended Travel CV Axles TO-8043ET, South Bend Rally Clutch, ES & Whiteline Bushings, MagnaFlow Cat-Back, Deck-Plate Mod, 4.56 Yukon Gears, Yukon Grizzly Rear Locker, Bushwacker Flares, 16x8 Wheels w/ 285/75 General Grabber AT2, 229K+ Miles
Zhehan is offline   Reply With QuoteReply With Quote
Old 09-30-2024, 10:11 AM #3
St Runner's Avatar
St Runner St Runner is offline
St Runner will become famous soon enough
St Runner's Avatar
Check your rear control arm bushings If they are shot it will clunk
1997 SR5 4x4
R150f swap E-locked 4.30 gears
Tundra 231 brakes LC 80 rims 285/75/16
2001 SR5 4x4
St Runner is offline   Reply With QuoteReply With Quote
Old 09-30-2024, 12:53 PM #4
That's good advice, but he did mention that it's louder when the wheel is turned, so it's more likely a front end problem. My money is on the upper ball joints.
Old 09-30-2024, 08:40 PM #5
Real Name: Forrest
Real Name: Forrest
Thanks for the advice I plan on keeping my 4runner for a while so I went ahead and ordered poly bushings for the upper and lower control arms in the rear and some moog Upper ball joints, I will send an update when Parts come in.
Old 10-03-2024, 10:00 PM #6
Let us know how it goes!
Old 10-04-2024, 11:25 AM #7
Daryl Elmore Daryl Elmore is online now
Daryl Elmore is on a distinguished road
You can rule out the sway bar by just disconnecting it and see if the noise goes away. My rear wheel bearings started making a clunking sound when they went out, you might check the front wheel bearings too.
Daryl Elmore is online now   Reply With QuoteReply With Quote
Old 10-04-2024, 11:44 AM #8
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
fortunately the upper ball joints are not a poor design like our lowers, you will probably be fine with moog uppers, previous owner of mine put on aftermarket uppers and lowers, but I switched out to lower oem quickly
2002 tundra ac v8 4wd
1969 kharmann ghia
bar , car , rods , sway , tie
Mystery of the rear flex clunk; chapter 2 jross20 3rd gen T4Rs 31 11-24-2019 09:33 PM
Mystery “Clunk”, ABS Light flashes, brakes lock briefly? cognus 4th Gen T4Rs 3 02-15-2019 01:23 PM
The F#*@)$^g Mystery clunk - rear hatch? stevets 3rd gen T4Rs 2 02-05-2018 10:32 AM
Another "Mystery Clunk" Thread MarkinWMich 4th Gen T4Rs 1 08-26-2014 10:29 PM
Mystery Clunk... michael833 3rd gen T4Rs 11 10-21-2011 10:25 PM
