Real Name: Tim
Real Name: Tim
If you're seeing it on the exhaust crossover pipe, it could be coming from a leak from one of the many coolant hoses at the back of the engine near the firewall. I'd investigate there before doing anything drastic. If you take the plenums off, you can get a better look at all the coolant hose connections. I'd do a cooling system pressure test to help you locate the source. You can pick up a pressure tester for pretty cheap or maybe even rent one for free from an auto parts store.
