Old 10-22-2024, 12:28 PM #16
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Originally Posted by blarchitect View Post
Yes, the air was blue with all the cuss words, but my selection of pick tools and pliers saved the day.
I guess since I've taken the throttle body and plenums off so many times, I made quick work of it.
The oil cooler hoses and resealing the oil cooler to the block was the biggest pain in the butt. I'm going to put out a separate video for that job, which will be the same footage from the complete coolant hose video. I decided it should be its own separate video, because so many people have asked for help with replacing those hoses or asking how to fix an oil leak from the cooler.
Old 10-26-2024, 10:51 PM #17
SuddenStorm SuddenStorm is offline
SuddenStorm is on a distinguished road
Now I wish I had replaced all these when I already had it apart when I did the valve cover gaskets a few months ago. Adding it to the list of "Things I want to do in the hopes of never being stranded"
SuddenStorm is offline   Reply With QuoteReply With Quote
Old 10-28-2024, 09:16 AM #18
JohnMc JohnMc is offline
JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all
I let a few semi-related tasks build up and did them in on coordinated effort. Replaced the original steering rack (with a new OEM rack, rebuilt racks never last very long in my experience), the oil cooler hoses and seals, the power steering pressure and return lines (pressure line was starting to look a tiny bit 'damp'). Reaplced the front diff (with an Eaton e-locker diff in 4.88 gearing from East Coast Gear), and resealed the oil pan.
Much better access to get to some things with other things our of the way. I have a 1" body lift which makes access to the side of the motor through the front hweel wells a little better, but it's still a miserable job getting to those oil cooler hoses.
JohnMc is offline   Reply With QuoteReply With Quote
engine , heater , hoses , maintenance , miles
Coolant / heater hose replacement Sgt. Rock 5th gen T4Rs 2 07-17-2020 09:58 PM
Coolant hose help LexsCTJill 4th Gen T4Rs 18 06-14-2020 08:45 AM
Help me identify this coolant hose! sc-4runner 4th Gen T4Rs 14 01-10-2018 02:01 AM
V8 Radiator Hose - Silicone hose replacement? t-rex grrr 4th Gen T4Rs 3 10-16-2015 12:14 AM
Coolant from end of Hose mjquillici Classic T4Rs 3 08-29-2014 07:15 PM
