Old 11-14-2024, 11:30 AM #16
RumHam26 RumHam26 is offline
RumHam26 is on a distinguished road
Well just to follow up with this - my intermittent ABS problem stopped happening for now. I tested the speed sensor in question with a multimeter and it tested the same as the new one, so I left it. The screw was a little loose, but it seemed it was seated really well.
I guess if the problem returns I'll try just unplugging one of the speed sensors to disable the ABS until I can take a look at other possible causes.
RumHam26 is offline   Reply With QuoteReply With Quote
abs , disable , fuse , issue , pull
Am I correct, to reset a CEL, unplug the battery of pull the EFI fuse?? Jeff T 4th Gen T4Rs 5 02-12-2014 02:51 PM
pull a fuse or cut a wire for tc? moconst 5th gen T4Rs 2 05-06-2013 04:51 PM
Trying to pull ABS fuse ! kennyb3030 3rd gen T4Rs 3 03-29-2011 06:31 PM
which fuse to pull? 4ballin 3rd gen T4Rs 1 04-15-2010 12:34 PM
Is there a fuse I can pull for the antenna motor on my 99 ltd? lbrowne Engines / Suspension / Wheels / Tires / Audio / Accessories 5 03-04-2008 01:34 PM
