Originally Posted by GhostRing
What did the air filter & box look/feel like?
One drop on the bottom of the box, filter felt maybe just a tiny bit damp, but certainly not as wet as I'd expect it to need to be to cut airflow by that much. Of course, that was after the symptoms had quit, so maybe it dried itself more, but I would have expected immediate rough idle at least if had gotten soaked.
I could get the RPM up just fine in lower gears, just not enough power to do it in 3rd. ISTR that being the most obvious effect of disconnecting the MAF in the Escape: it would act fine gunning it in park, and drive fine at low speeds, but then not have the power to get over 35-40.
Is there anything electrical I could easily have hit via the grill or wheelwells that would cause it to be lacking in power?
