There are two things that need to happen to make warm/hot air come out of the vents (assuming good coolant flow is possible through the core...) - the valve on the firewall needs to open, AND the blend door needs to force air through the heater core instead of around it.
Step 1 is to check the valve on the firewall (in the engine bay) is moving from cold to hot with the dash controls, then next is to check if the blend door actuator is working (for 01/02, even the 'manual' AC 4Runners had actuators instead of cables).
I don't have an 01/02, so somebody else can hopefully provide pictures of where to look for the blend door actuator...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
