Old 11-16-2024, 02:51 PM #1
mtncrzr mtncrzr is offline
mtncrzr is on a distinguished road
Battery Drained overnight. What should I check?
Battery is 1 year new, heavy duty.
Drained dead completely, after a couple of days while not used. No dash lights, nada.
Previous drive was just a couple of miles, so I think it's a current drain issue and not a charging issue.
There are no aftermarket electronics, sound, etc.
Battery terminals and wires are clean and tight.
Wasn't banging around on trails so nothing should be knocked loose/shorted.
Once the battery is re-charged, I'll test the alternator for 14V, check visually for any loose wires (not an expert at spotting them as I spend more time in the driver's seat than under the hood)
And then I guess a parasitic draw test
(using voltmeter, pull fuses 1x1 to check which circuit is draining) >
How to Find a Parasitic Battery Drain: 11 Steps (with Pictures)
Is there anything I should check first?
Maybe a relay, or anything else that is known for shorting out?
Thanks!
mtncrzr is offline   Reply With QuoteReply With Quote
Old 11-17-2024, 01:48 AM #2
wcjeep's Avatar
wcjeep wcjeep is offline
wcjeep has a spectacular aura about wcjeep has a spectacular aura about wcjeep has a spectacular aura about
wcjeep's Avatar
Check the metal tips of the fuses for voltage. Looking for changes of micro volts. If your meter is sensitive enough it will see voltage change across the fuse during high amp draw. Good reading is zero volts across a fuse.
Or, pull the negative cable. Place your multimeter in Amperage setting. Some meters require physically moving a lead on the meter. Place one lead on negative cable, second lead on the battery. This will read all amperage draw from the battery. Some vehicles can take upto 30minutes for all normal battery draw operations to end. Not sure on 3rd gen normal draw. Expect around .02 amps or less for normal parasetic draw. This powers engine computer and stereo clock. Be sure all car doors remain closed. All lights including dome and under hood remain off. Opening the door might restart your 30min stand down timer. Start pulling fuses until problem goes away. This isolates the problem circuit.
Infrared tech can see the heat from high draw items.
2018 Offroad Premium w/KDSS
1993 Jeep YJ w/stuff
wcjeep is offline   Reply With QuoteReply With Quote
Old 11-17-2024, 06:04 PM #3
davidch davidch is offline
davidch will become famous soon enough
Charge the battery well. Then unplug the radio/cassette/etc unit.
You cannot just pull the radio fuse: the radio gets power 24/7. Why? Well, to maintain the preselected stations, and maybe the clock if the unit has one.
Also, and one doesn't typically think of this, but you can eject cassettes or CDs without inserting the key and having the ignition on. Now, you can't feed a cassette or CD into the device, but it takes power to eject.
My wife's 2002 Outback had a parasitic draw that I narrowed down to the CD player. On that vehicle, as on some Toyotas, the CD is a separate unit from the radio/cassette. A few years ago a neighbor's kid was driving a 2006 Honda Accord. It too, had a parasitic draw that I traced to the radio unit. On that car, the radio is build into the dash unit that also controls HVAC. Replacing was too expensive give the value and intent of the car. So I installed a toggle switch under the dash and wired the 24/7 radio feed through that. The kid has to remember to turn that switch off when parking the car.
davidch is offline   Reply With QuoteReply With Quote
Old 11-17-2024, 08:10 PM #4
thennen's Avatar
thennen thennen is offline
thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold
thennen's Avatar
Check for parasitic drain first. Could be that.
This can also be an early sign of worn alternator brushes. Simple to replace, and easy to see visually if they're worn. If they have near 200k miles on them, replace. $20.00
thennen is offline   Reply With QuoteReply With Quote
Old 11-18-2024, 01:23 PM #5
Atomic_Dog Atomic_Dog is offline
Atomic_Dog is on a distinguished road
I would still get the battery checked first. It's the easiest thing to check.
2001 SR5 130k miles
Atomic_Dog is offline   Reply With QuoteReply With Quote
Old 11-18-2024, 01:38 PM #6
RodrickHeffley's Avatar
RodrickHeffley RodrickHeffley is offline
RodrickHeffley has a spectacular aura about RodrickHeffley has a spectacular aura about
I believe we're all overlooking that OP is looking for support for a 5th gen. This is the 3rd gen section. @mtncrzr , try posting this in the 5th gen section. They can help you better than we can.
1998 4Runner Limited 4WD w/Rear Locker
281k Miles
Build Thread
RodrickHeffley is offline   Reply With QuoteReply With Quote
Old 11-18-2024, 05:59 PM #7
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Where did everyone overlook that, I don't see where he stated what year and all of his other posts on the forum is in the 3rd Gen section??
2004 Limited V8
Old 11-18-2024, 06:29 PM #8
Hungryhawk Hungryhawk is offline
Hungryhawk will become famous soon enough
Note the power seat controls are always on because I can adjust my seat from my wife' setting to mine without turning the key.
Seat covers can press on the switches. The wires are loose under the seat, any chance something got caught?
Hungryhawk is offline   Reply With QuoteReply With Quote
Old 11-18-2024, 08:22 PM #9
He posted this twice, at the top of the other post (same exact battery problem as this thread), he mentioned the year as being 2018
281k Miles
Build Thread
Old 11-18-2024, 10:39 PM #10
Real Name: Skip
Real Name: Skip
So we all didn't overlook it...only those who may have seen the other thread.
I just went and read the other thread, it actually says... "2018 4X", didn't really state that it's a problem with a 2018 T4R ...what that means is anybody's guess, does it mean he has 4 2018 T4Rs with battery problems....or did he have this battery problem 4X since 2018...or with 4 different batteries...who knows other than the OP, maybe he'll stop back by and explain...again who knows!!
2004 Limited V8
Old 11-19-2024, 07:59 PM #11
Doc995 Doc995 is offline
Doc995 is on a distinguished road
Check that battery and check it again....I cannot tell you how many bad-out-of-the-box batteries i've experienced over the past few years. i don't know what they're doing but their quality is terrible lately.
Doc995 is offline   Reply With QuoteReply With Quote
battery , check , couple , drained , test
Clicking Noise and Drained Battery alleghenyman 3rd gen T4Rs 15 08-24-2022 08:15 PM
Battery drained while winching G_Raw 3rd gen T4Rs 13 12-02-2019 03:51 PM
Battery Getting Drained Matts05runner 4th Gen T4Rs 11 01-17-2018 06:38 PM
Battery being drained while car is off Homebrewers wife 4th Gen T4Rs 11 07-11-2012 05:24 PM
battery drained gimpey03 3rd gen T4Rs 6 05-29-2008 09:15 AM
