Old 11-18-2024, 09:56 PM #1
Gull81 Gull81 is offline
Gull81 is on a distinguished road
Timing belt job - extra 12mm bolt
Hey all -
I went ahead and finished the timing belt job today with your help. Thanks all for you advice. I'm kicking myself big time and wanted to see if anyone had advice regarding an odd situation I found myself in.
I removed the bolts for the water pump and put them aside. When I went to reinstall the water pump I had 8 bolts instead of 7. I figured I would find where the extra bolt came from by the time I put everything back to together - dumb idea.
Anyways - the best I can figure is that I likely took this bolt off by accident when taking the water pump off and never replaced it.
https://imgur.com/a/szQ92MU
Can anyone tell me what it is I took off and if it's an issue. I am hoping it is nothing because I really cannot be going back down the deep into the engine again.
Gull81 is offline   Reply With QuoteReply With Quote
Old 11-18-2024, 11:26 PM #2
Doing some more research - seems like I removed a bolt for the oil pump. I guess if I start leaking oil there I will know why. I hope it is well sealed and the (presumed) missing bolt will not be missed.
Any advice / opinions from the more experienced folks welcome
Old 11-19-2024, 01:58 AM #3
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
You're just inviting big trouble, fix what you messed up, if the pump leaks oil, and I'm sure it will at some point it will ruin the timing belt and then you'll be redoing the entire job not just put the bolt you forgot back where it goes, much more work and time...BUT it's your truck,money and time!!!
2004 Limited V8
Old 11-19-2024, 02:21 AM #4
Twisted Sid's Avatar
Twisted Sid Twisted Sid is offline
Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about
Extra pieces are just over engineering
'99 4Runner SR5: 5VZ, 2wd, AT, 400k+ club
'94 Pickup: 2wd, 22RE, 5spd, (3RZ swap in progress)
Front: Total Chaos Uniball Kit, Fox 2.5 8'' coilover
Rear: Deaver F67 Leaf Springs, Fox 2.0 14'' Reservoir Shocks, E-locker Axle 4.88 Gears 33x10.5 BFG ATs
Twisted Sid is offline   Reply With QuoteReply With Quote
Old 11-19-2024, 06:08 AM #5
To access that bolt I would be redoing the whole job at this point anyway. It's deep in there and the timing belt would potentially have to come off as well to access it.
Old 11-19-2024, 09:43 AM #6
thennen's Avatar
thennen thennen is offline
thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold
thennen's Avatar
Maybe Timmy has an idea or two...
thennen is offline   Reply With QuoteReply With Quote
Old 11-19-2024, 11:24 AM #7
As far as I can the bolt seems to be a bolt that holds the oil pump assembly to the motor but doesn't seal the oil or anything like that. I think it will be okay.
New problem this am - drove and had some leaking. Parked and popped the hood and coolant had gotten in the fan and sprayed on the motor. I imagine this means my radiator is now leaking. I look it out to the do job and don't think I damaged it in anyway.
I'm going to give it som time and just pray it will seal itself off.
Old 11-19-2024, 01:28 PM #8
2TH4IST's Avatar
2TH4IST 2TH4IST is offline
2TH4IST is a glorious beacon of light 2TH4IST is a glorious beacon of light 2TH4IST is a glorious beacon of light 2TH4IST is a glorious beacon of light 2TH4IST is a glorious beacon of light
2TH4IST's Avatar
I'd find where that bolt went and put it back on. Better safe then sorry.
There's danger lurking around every corner, that's why I propose we make all of our buildings round.
I don't remember the time I was human that's why I don't understand anybody.
2TH4IST is offline   Reply With QuoteReply With Quote
Old 11-19-2024, 09:12 PM #9
thezentree's Avatar
thezentree thezentree is offline
Real Name: Robert');DROP TABLE Students;
thezentree is just really nice thezentree is just really nice thezentree is just really nice thezentree is just really nice
thezentree's Avatar
Having done a timing belt myself this past weekend, I get the urge to ignore it. I would lose sleep over it though. I bet you can sneak that bolt in past the timing belt and crank pulley. Still gotta pull the drive belts and fan out, but you dont have to take the radiator out (I didn't) and you probably don't even need to remove the radiator hoses if you're just trying to get the fan bracket out. The upper timing belt cover can just hang loose on the upper radiator hose.
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
thezentree is offline   Reply With QuoteReply With Quote
Old 11-20-2024, 10:37 AM #10
Previologist Previologist is offline
Previologist will become famous soon enough
I also accidentally removed an oil pump bolt during my wp job, I believe that same one. Worse, when I went to put it back in it seemed to have stripped. I was afraid to torque it for fear it would have to be drilled out, and what fun that would be...couple thousand miles later I have had no problems. I just put my skid plate back on yesterday and there was no leaking in that area.
97 4runner 5-speed 3.4
Previologist is offline   Reply With QuoteReply With Quote
Old 11-21-2024, 12:40 PM #11
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
well you have had practice doing a belt, think how much faster you would be next time. I would pull it down and put the bolt in
2002 tundra ac v8 4wd
1969 kharmann ghia
belt , bolt , pump , time , water
Timing belt job bolt identification 99_4runnerltd 3rd gen T4Rs 8 08-24-2020 01:51 PM
Did Timing Belt got extra bolt alumarine 3rd gen T4Rs 7 03-23-2017 02:46 PM
Timing belt job left over bolt... Help? KainDrag 3rd gen T4Rs 4 06-23-2015 04:58 PM
