Old 11-22-2024, 11:42 AM #31
spartacus's Avatar
spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of
spartacus's Avatar
Might be worth a shot, try switching the bolts on the c clamp.top to bottom. I belief one bolt is longer then the other.
Old 11-22-2024, 01:07 PM #32
GhostRing's Avatar
GhostRing GhostRing is offline
GhostRing is a jewel in the rough GhostRing is a jewel in the rough GhostRing is a jewel in the rough GhostRing is a jewel in the rough
GhostRing's Avatar
Originally Posted by JohnMc View Post
They're there to allow it to move a *little* bit, and then deflect back.
In the video it seems like the rack is sliding sideways back and forth way too much. That is, very directly, the steering wheel turning and the wheels aren't (as much as they should).
Agreed.
Mine doesn't seem to move as much as his, but now debating the effort to switch to the polys for somewhat limited improvement. I agree it may
not be a good idea to solidify the rack mounts, and I doubt I'll do the
billet U Clamp, so I'll be looking into other potential issues first.
@Kmurt have you checked all of your alignment tabs?
I've had a time or 2 when the alignment slipped because a tab was bent.
In fact, one alignment they went right over it! (no longer using that shop)
Build Etc...
If it ain't broke, fix it 'til it is.
GhostRing is offline   Reply With QuoteReply With Quote
Old 11-26-2024, 03:05 AM #33
Qusak Qusak is offline
Qusak is on a distinguished road
Originally Posted by Kmurt View Post
I’m still chasing an issue where my steering rack has a lot of movement in it.
I have installed a brand new OEM steering rack, OEM rag joint, OEM outer tie rods and energy suspension D-shaped bushing in the rack.
I have torqued every nut and bolt to spec and followed Timmy the toolmans video on how to replace the rack. I’m really not sure what to do at this point. Is everything supposed to be tightened with the wheels on the ground? I torqued everything with the vehicle on jack stands. bazoocam chat Could the OEM bushings be bad already?
Here is the last thread following up to this new thread I created: Steering Wheel Issue
Here is a video of my problem: https://www.youtube.com/watch?si=zSyax75zJnlm6Crj&v=_2HlE-UqPS4&feature=youtu.be
Undoubtedly, the rack is in motion. The "through" bolts' bushings are undergoing deformation. Could it be that you received the incorrect bushings?
Qusak is offline   Reply With QuoteReply With Quote
Old 12-05-2024, 09:26 AM #34
Kmurt's Avatar
Kmurt Kmurt is offline
Kmurt will become famous soon enough
Kmurt's Avatar
In fact, one alignment they went right over it! (no longer using that shop)[/QUOTE]
I was under the 4runner the other week and actually found one of the cam bolts slightly loose on the drivers side and passenger side. Then I went ahead and tightened every other bolt i could reach including ball joints and they all seemed okay.
I disconnected the rag joint and made the steering wheel straight and now at least when im driving the steering wheel is straight, but will still pull to the left when i brake hard.
2001 4Runner SR5 4x4
Kmurt is offline   Reply With QuoteReply With Quote
Old 01-06-2025, 04:18 AM #35
GhostRing's Avatar
GhostRing's Avatar
Bit of an update to my steering saga-
I went ahead and re-installed the rest of my poly bushings into the rack
and it did make a marked improvement (duh) in the tracking and input.
I can't take for granted the energy that rocks/snow/whatever transfer to the bushings.
I'm still getting a little darting to the left with a brake stab, but not nearly
as aggressively as before. I'm installing a new booster next week-ish,
so I'll attempt to bleed things a million times again and see if I can get it more betterer...
Build Etc...
oem , rack , steering , thread , torqued
removing steering wheel play by replacing the steering rack shaft trashboy 3rd gen T4Rs 13 12-02-2024 07:42 AM
Excessive play on drivers side steering - replace steering rack guide cheeser 3rd gen T4Rs 17 05-05-2022 08:15 PM
How play in the steering rack bushings is normal? fdbyrne 4th Gen T4Rs 6 06-09-2015 10:20 AM
Steering rack play mountainbiker42 3rd gen T4Rs 3 06-20-2014 11:28 PM
anyone else have some wicked play in their steering rack?? cordrayj1 3rd gen T4Rs 17 06-14-2013 01:16 AM
