11-24-2024, 04:01 AM
Parts of cluster turn off randomly
Hi,
On my daily driver runner parts of my cluster turn off at random. The temperature guage, and seatbelt light, etc. Tapping it usually brings them back on. Anyway know off the top of their head the fix for this?
Here's a video of it happening
I assume I'm going to have to remove the cluster and inspect it.. just curious if anyones dealt with and fixed this issue.
Thanks
'00 5VZ 5spd 4x4 E-Locker 174k (Project)
'98 5VZ 5spd 4x4 180k "Bob" (Nightmare/daily)
'97 5VZ 2runner 250k "2Runner" (Parts Car)
'97 3RZ Auto 4x4 387k "Little runner" (Sold!  )
11-24-2024, 10:36 AM
Similar random issues I've seen resolved by a new printed circuit for the cluster.
'02 Limited 4x4 AT - Stock ~181k miles
Thundercloud aka metallic dirt
11-24-2024, 04:48 PM
I don't have this issue, but recently replaced my printed circuit board. I went with a used cluster, stripped it down for the board. Check Amayama with your vin, under meter 8301 towards the bottom of page. Might still be available new.
Tip if you remove your cluster. Place a towel over all the metal bits of the steering column. The printed board also runs along the bottom of the cluster. One wrong move and you can cut or short the printed circuit board. Ask me how I know lol.
There's danger lurking around every corner, that's why I propose we make all of our buildings round.
I don't remember the time I was human that's why I don't understand anybody.
11-24-2024, 10:57 PM
Does this one look right?
Also $300 for the clock is wild
11-25-2024, 11:24 AM
That looks right. But hey you want a new clock, it's only money lol. Most expensive clock lol.
11-25-2024, 04:47 PM
Oh no! I have the same issue with my clock. Didn't know about that! Sheesh!
11-26-2024, 01:51 PM
Originally Posted by brillo_76
There was a guy on ebay rebuilding the old toyota dash clocks. I dont know if anyone out there is rebuilding those now..
It is mostly just a corrosion issue on the connector to the PCB. That is handled by some springs - no solder or anything. This can be fixed with a cleaning or directly (carefully!) soldering the pins.
The cluster issues are different and are generally broken traces on the flex PCB. I had to replace mine years ago... my brake lights, turn signals and reverse lights all got linked together (missing ground on the flex board).
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
11-26-2024, 03:39 PM
Real Name: Jon
Real Name: Jon
Interesting.. Mostly we dont have pcb issues here.. Maybe that is it doesnt get as hot here.. I haven't had a pcb fail on any Toyota yet and lots of my rigs have the age on them too. Interesting indeed. :-)
11-27-2024, 12:56 PM
Real Name: 3 Bears
Real Name: 3 Bears
can this also cause some of the cluster lights to flicker on and off. The one above my fuel gauge goes out, then comes back on and can be days for either one
2002 tundra ac v8 4wd
1969 kharmann ghia
11-27-2024, 03:18 PM
Possibly, though I'd suspect the holder or bulb connections if it was just one of the backlight bulbs.
12-07-2024, 04:06 AM
So yesterday I was at a junkyard to grab some interior stuff I'm missing, and thought hey, I'll grab one of these PCB's for funsies. The guy didn't know what it is so he didn't charge me for it.
I'm not sure about what it came off of either as the cluster was just on the ground inbetween a few 4runners, but they sure look ALMOST the same. Any reason I shouldn't just throw it on and hope for the best?
On truck:
From Junkyard:
Since clocks were brought up, I also fixed my clock, one of the little black things on the back of it had a broken joint. I didn't even use any tin, just heated it up with the iron and it started working again.
12-07-2024, 06:55 PM
It looks similar, but there are some differences. Some of the jumpers are in a different location. I'd just triple check to make sure it's the same. If it's not I'd probably pass on it and find one from your exact year and trim level.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
