Old 11-29-2024, 04:52 PM #1
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Master Cylinder Replacement (1996-2000)
Hey Dudes,
If you ever need to replace the master cylinder on your 1996-2000 rig, this video will show you how to get it done. I partnered with @JZiggy to bring you this video.
One comment we got from several people is there's a much less messy way to do the "Bench Bleeding" by using fittings and tubing that will direct the expelled brake fluid right back into the reservoir. Jordan and I were ignorant of this method and we just followed exactly how the Toyota FSM showed how to do the bleeding.
I found an affordable bench bleeding kit from Dorman. Amazon.com
The reviews are mixed on the Dorman kit, but I figured I'd give it a shot because it's very affordable. There are kits with aluminum fittings, but those are pretty pricey. Or, you can simply buy some brass fittings and hose at a hardware store and make your own bench bleeding kit.
I hope you Dudes like the video.
Old 12-04-2024, 01:25 PM #2
I was lucky enough to have an extra set of hard lines to be able to do that. Definitely much better than figuring out a way to catch (and waste) a bunch to get the bench bleed procedure done. This is a good video to have since the bench bleed procedure is a bit different than a 'normal' master cylinder.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
bench , bleeding , fittings , kit , video
Brake Accumulator/Master Cylinder Replacement-Squeal Fix eng208 4th Gen T4Rs 25 10-10-2022 11:53 AM
Brake Booster/Accumulator/Master Cylinder Assembly Replacement eng208 4th Gen T4Rs 32 07-25-2021 02:55 AM
2001 Master Cylinder Removal/Replacement Questions Marshall Man 3rd gen T4Rs 9 11-29-2012 01:05 AM
Master Cylinder Replacement FirstGenRunner Classic T4Rs 3 06-18-2010 10:44 AM
Master Cylinder replacement on my 1997, did I get hosed? Recoil Rob 3rd gen T4Rs 0 11-07-2006 07:58 PM
