Originally Posted by phattyduck
Unless you are adding weight, re-use your stock springs. Get the 4Runner specific 5100's, put it up two notches (1.5" lift) and maybe a tiny (1/4") top plate spacer. That solves the front. 4Runner specific 5100's in the rear with either OME2906 or 2980 springs.
Quick and easy, and won't get you so high you need all the other crap to make it align and handle (upper front arms, etc.).
This sounds pretty close to the other rout I'm considering. I was thinking 4runner 5100's, 99 coils front and 99's plus a 20mm spacer in the rear. Do the stock coils still ride nice on the second notch?
I'm hesitant on the emu coils because I've read they are stiff and I don't like that the 906 is shorter than stock.
For weight I need to build a rear bumper (stock one is trashed) but I don't think it should really add more weight than the stock bumper/hitch.
In the future I would like a winch but that isnt happening now or any time soon.
"and won't get you so high you need all the other crap to make it align and handle (upper front arms, etc.)."
I really want to avoid this. I don't mind adjusting the panhard bar but I don't want to get into aftermarket arms and working out the issues that can come from too much lift right now.
