Old 12-05-2024, 01:43 AM #1
mendozer mendozer is offline
mendozer is on a distinguished road
Cold weather...blinkers out?
I noticed the other day leaving from work that neither of my blinkers worked. Not the bulbs themselves but the indicators on the dash didn't come on, nor did the clicking. As if pushing the stalk on the steering column did nothing. Later in my drive i was at a red light so out of curiosity i shut the car off and restarted. then it worked. i thought hmm, weird electrical glitch.
then today leaving work the same thing happened. this time i wondered if it was warmth and not a starting issue. so i drove for a few minutes let everything get to normal temps like hot air coming out and such...blinker worked. so...something about the cold is making my steering column stalk not work right. and what's even more bizarre is it's not happening first thing in the morning when it's the coldest.
what the heck?
mendozer is offline   Reply With QuoteReply With Quote
Old 12-05-2024, 03:30 AM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
what the heck?
I have had the contacts wear out on the column stalk before. It was on a 1998. I bought an aftermarket and it wouldn't stayed locked in until the steering wheel went back. So i put the new contacts on my old column and never had an issue again. Its a possibility that those contacts are worn down. Thought it may not be. When i pulled my stalk apart you could see them very badly warn my left side went out If I remember correctly.
Do your hazards function properly? As if your hazard switch is not making good contact that too will kill the turn signals as well. Common if you had the center dash console out recently. One time I forgot to plug that switch back in changing a radio out. So I would verify that connection is good as well.
Old 12-05-2024, 12:45 PM #3
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
agree with above post, I cant imagine the cold making it do it...I know cold
2002 tundra ac v8 4wd
1969 kharmann ghia
Old 12-05-2024, 02:48 PM #4
alumarine alumarine is offline
alumarine has a spectacular aura about alumarine has a spectacular aura about
I had a problem when using my turn signal stalk for left turns it wouldn't activate the blinker.
I had to take the switch apart in the column.
I followed these instructions.
It's worked great for a few years now.
BLINKER STALK DIY FIX FOR 3RD GEN (should work on many others as well)
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
Old 12-05-2024, 05:11 PM #5
Riceye Riceye is offline
Riceye will become famous soon enough Riceye will become famous soon enough
Sounds like your blinker fluid froze.
Sorry, someone had to say it.
_________
2000 SR5 five speed. Everything works, even the antenna. No special mods; It's my canoe, kayak and dog hauler/winter beater.
I find that things usually go well right up until the moment they don't.
Riceye is offline   Reply With QuoteReply With Quote
Old 12-06-2024, 02:08 AM #6
blinker fluid you're right! OMG
It didn't happen today so i'll have to wait to re-test with hazards.
Old 12-09-2024, 03:19 PM #7
The cold weather formulation should work better for the OP. Check the owners manual for the right spec.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 12-09-2024, 07:44 PM #8
Okay so it happened again just a few minutes ago driving and so I tried to push the hazards which then made the lights go on. So I thought oh my stock is bad. But then I realized that in order to get the hazards I had to move my cell phone holder out of the way which was just barely touching the hazard button and then I messed around with it and found out that if you do depress that button ever so slightly like not even enough to trigger the lights to come on the blinker will not activate. So all in all it was simply my cell phone holder barely resting on the hazard button causing all of this hoopla
Old 12-09-2024, 08:19 PM #9
fourwd1's Avatar
fourwd1 fourwd1 is offline
Moderator
Real Name: The Chosen One
fourwd1 is just really nice fourwd1 is just really nice fourwd1 is just really nice fourwd1 is just really nice fourwd1 is just really nice
Moderator
fourwd1's Avatar
Damn, you beat me to it.
And don't forget about putting winter air in your tires.
'89 4Runner SR5 - stock
fourwd1 is offline   Reply With QuoteReply With Quote
Old 12-10-2024, 01:12 AM #10
i only put winter air in my tires. i actually save it in tanks for the rest of the year. it's the best.
funny that i figured out it was the hazard switch. what a doufas! lol
column , stalk , steering , work , worked
Coilovers or other for cold weather? razzyrazz 4th Gen T4Rs 6 02-27-2017 04:13 PM
Cold Weather Antifreeze madeinhb 4th Gen T4Rs 2 08-29-2016 10:08 PM
Cold weather & weather stripping Bourbonator 5th gen T4Rs 1 12-05-2015 08:37 PM
Cold weather = 10mpg???? Anybody else? Former_Jeeper 3rd gen T4Rs 9 11-11-2013 01:53 PM
cold weather MPG sully 3rd gen T4Rs 2 11-13-2008 01:13 PM
