Old 12-12-2024, 11:08 AM #1
talkstometal talkstometal is offline
talkstometal is on a distinguished road
4.56? rear diff selection help
edit: changed title after learning 4.56 carrier is different
looking to buy a rear with 4.56 gears. where should I look? there are not a lot of junk yards near me. I looked on ebay and didnt see any. I do not need complete rear, just diff/gears unit. also, what years interchange? only 98-02?
any good places to source? or anyone have one for sale? whats the going rate?
current daily 2018 highlander, 1999 3rz 4runner
previous fun cars...2009 bmw m5, 650rwhp, audio stuff
1993,1986,1988,1991 rx7 v8 swaps....
1990 4runner
https://y6y3b6a8.stackpathcdn.com/signaturepics/sigpic730237_1.gif
talkstometal is offline   Reply With QuoteReply With Quote
Old 12-12-2024, 02:30 PM #2
'96-'02 are compatible, but the 4-cylinder (and thus 4.56's) are only '96-'00.
Try Car-Part.com--Used Auto Parts Market to search junkyards. Definitely check carefully ring and pinion teeth before purchase - the 4.56 is pretty rare (uses a different carrier than all the other ratios, FYI)
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 12-17-2024, 10:31 AM #3
uses a different carrier?? damn.
so the 3.9 and 4.1 same.
4.3 are locking and different
4.56 different from both above?
I was going 4.56 before, because I thought it was a drop in. What would be the cheapest option to get 4.3 or higher?
1990 4runner
Old 12-17-2024, 11:34 AM #4
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
You can order that differential from East Coast Gear Supply. When it arrives, you pull yours, put it in the box the rebuilt one came in, and ship it back to ECGS to satisfy the core charge. Easy Peasy.
Old 12-17-2024, 03:50 PM #5
All the available factory gear ratios will bolt in place (non-e-locker) of each other. The only issue with the factory 4.56 carrier is that no aftermarket gears work on them.
Tim has a good suggestion - just re-gear and send your current 3rd member back to ECGS... Then you aren't stuck with 4.56 as your 'best' option - maybe 4.88's would be better for you?
Old 12-17-2024, 05:04 PM #6
if money was of no concern then Tims easy switch out is the best option. but that gear costs 4x what I paid for this 4runner! ha. I got a great deal.
so...the 4.56 will drop in?
will aftermarket gears work on my 3.90?
Whats the most cost effective route to get 4.3-4.8 gearing?
1990 4runner
Old 12-17-2024, 06:37 PM #7
A complete 4.56 third member will drop in. Just the gears of an OEM 4.56 will not fit/work on your diff/carrier - is that more clear?
Cheapest? Find a crashed 4Runner with the right gears, buy it and part it out. Make some $$$ that way...
Start calling junk yards... (see the link I provided above) You might find they want $400 for a 200k+ mile used diff, and suddenly $800-1000 to ECGS for a fully rebuilt diff sounds reasonable... (then you start to contemplate an LSD/locker, etc...) - or you might find something for $150 and it will be no problem.
Old 01-14-2025, 09:42 AM #8
4.56? rear diff selection help-img_2138-jpg
4.56? rear diff selection help-img_2137-jpg
4.56? rear diff selection help-img_2136-jpg
4.56? rear diff selection help-img_2135-jpg
Found this setup. Guy says it’s “It’s an 8” IFS Toyota from truck or 4 runner 1986 to ? (Not sure).
Can you guys tell from images if that diff will fit into a 99 rear? It looks like the axle isn’t the same.
4.56? rear diff selection help-img_2138-jpg  4.56? rear diff selection help-img_2137-jpg  4.56? rear diff selection help-img_2136-jpg  4.56? rear diff selection help-img_2135-jpg
1990 4runner
Old 01-14-2025, 03:14 PM #9
Looks like an older "4-cylinder" diff.
The Ultimate Guide To Toyota Differential Information
(all 3rd gen 4Runners use a "V6" diff)
Old 01-14-2025, 05:02 PM #10
thanks for that link. yes, looks like that pic is 4cyl diff.
am I reading that right...? that: "4cyl diffs are swappable with the V6 and high pinion diffs."
so that picture of 4cyl diff will fit into v6 carrier?
1990 4runner
complete , diff/gears , good , rear , unit
Front Diff magnetic plug worse than Rear Diff normal? Rpede 5th gen T4Rs 0 03-08-2021 05:00 AM
2001 4runner Front Diff and Rear axle/Diff assembly. Corpus Christi, TX zwalker16 For Sale: T4R Items 5 08-24-2018 09:53 AM
97 Ltd 4wd no e-locker rear diff 3rd Member stuck on axle housing; Broken diff stud. azcat90 3rd gen T4Rs 19 09-08-2016 12:07 PM
Can I swap the innards of my rear diff with a locking rear diff from another 4runner? xx_independent_xx 3rd gen T4Rs 23 11-19-2013 11:19 PM
center diff vs. rear diff locks mtw290 Off-Roading 8 02-28-2009 02:49 PM
