Old 12-18-2024, 05:54 PM #1
OpenYota's Avatar
OpenYota OpenYota is offline
Real Name: Chris
OpenYota is on a distinguished road
OpenYota's Avatar
Real Name: Chris
ABS, parking brake light, brake alarm on, braking normally - Help!
I was normally driving today and came to a stop on a turn off and all of a sudden my brake alarm (constant sound), ABS light, and parking brake light came on.
I parked the car to inspect everything and didn't see any brake fluid leaks or low brake fluid in the reservoir (it's at the max line).
No ABS codes popped up except for a P0770 and P0442 but they have been there for a year plus.
My brake pedal is still firm and stops normally and my ABS pump motor still kicks on and off normally. No weird sounds from the master cylinder either.
When I put my car into ACC ON position the alarm and lights turn off after a minute or so but when I drive the car the alarm and both lights come back on after 5-10 minutes.
Any ideas what could be causing this issue?
2001 SR5 4WD
OpenYota is offline   Reply With QuoteReply With Quote
Old 12-18-2024, 08:33 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Your TC inst locking up code P0770
P0442 is evap leak .
Being when its moving it sounding like your VSC trac system is going crazy. IF the CEL is on it should be disabled the VSC TRAC lights should be on. Does the chirp or are the lights flashing?
Old 12-19-2024, 09:57 AM #3
OpenYota's Avatar
Real Name: Chris
OpenYota's Avatar
Real Name: Chris
Correct, VSC and TRAC lights are both on but have been for quite some time as I've had the P0770 since the tranny was rebuilt a couple years ago and have been fighting evap leaks for some time.
No lights are flashing, just the abs and brake light turning on with the subsequent constant brake alarm. Odd thing is, I have no brake fluid loss or trouble braking. Going to try and jump the OBD port in the engine bay and get the abs codes.
2001 SR5 4WD
Old 12-19-2024, 11:11 AM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Interesting.. I unfortunately have nohting at the moment. :-(
Old 12-19-2024, 12:51 PM #5
spartacus's Avatar
spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of
spartacus's Avatar
Check fuses and tailgate wiring looms for shorts.
abs , alarm , brake , car , light
Parking Brake Light Tyronmar 3rd gen T4Rs 11 12-16-2024 01:02 PM
2008 4Runner Parking Brake Warning Light & ABS Light Flicker Simultaneously sant6236 4th Gen T4Rs 55 07-15-2023 03:34 PM
Is driving 07 T4R with the parking brake shoes on, only hurting the parking brake’s jow 4th Gen T4Rs 2 05-15-2013 02:31 PM
Fixing the parking brake light. S Brake 3rd gen T4Rs 0 03-02-2013 06:27 PM
Parking brake light comes on and off pyrophite 3rd gen T4Rs 3 09-14-2005 07:40 PM
