Old 12-20-2024, 03:09 PM #1
Pyral's Avatar
Pyral Pyral is offline
Real Name: N/A
Pyral has a spectacular aura about Pyral has a spectacular aura about
Pyral's Avatar
Real Name: N/A
Removed a bolt on my engine that I didn't need to, did it hold anything important?
I'm doing the waterpump on my 3rz and I removed 2 or 3 bolts that I thought I needed to but didn't. I completely removed the bolt near the base of the dipstick tube.
I also loosened the nuts above the water pump (if we're going by shape, the one above the head and balls). I circled them in this diagram.
I didn't remove something holding a part in place inside the engine did I?
Also one of the long bolts that holds the water pump was heavily rusted because coolant went down it, how should I clean out the threads?
Removed a bolt on my engine that I didn't need to, did it hold anything important?-removedthing-png
1998 4runner 2.7 manual
Pyral is offline   Reply With QuoteReply With Quote
Old 12-20-2024, 03:35 PM #2
2TH4IST's Avatar
2TH4IST 2TH4IST is offline
2TH4IST is a glorious beacon of light 2TH4IST is a glorious beacon of light 2TH4IST is a glorious beacon of light 2TH4IST is a glorious beacon of light 2TH4IST is a glorious beacon of light
2TH4IST's Avatar
I don't have a 3rz, but you should be fine as I suspect they are just the timing chain cover bolts. I know someone else will chime in but I'm guessing they will be 14-15 ft-lbs for torque.
As for removing rust from threads, use a thread cleaner tap. They don't cut threads like a normal tap does. Or a bore brush a bit bigger then the bolt, use with a drill, then blow out.
There's danger lurking around every corner, that's why I propose we make all of our buildings round.
I don't remember the time I was human that's why I don't understand anybody.
2TH4IST is offline   Reply With QuoteReply With Quote
Old 12-20-2024, 06:18 PM #3
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Since you asked about removing rust from the threads of a "bolt" and not the thread of a bolt hole, you will need a "die" not a "tap" to clean the threads, you could probably clean them with a good stiff wire brush and some elbow grease but the die will do a better job, if you use a die to do the job, turn it a full turn or two onto the threads as if you're tightening a nut and then at least a 1/2 to full reverse turn to let the rust and debris fall out of the die and threads, rinse and repeat until you get all the threads clean.
2004 Limited V8
Old 12-20-2024, 06:34 PM #4
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
The sealing surface on my block for the water pump isn’t very smooth, I think I have to use a small amount of RTV. What kind of RTV should I use to stop the imperfections from leaking?
Old 12-21-2024, 01:34 AM #5
2TH4IST's Avatar
2TH4IST's Avatar
Can you get the surface smoother, by scraping or is it damaged like gouged?
I've used this in the past with good success. Just don't put to much on.
Gasket Maker
Ultra grey
Old 12-21-2024, 12:11 PM #6
LrndTheHardWay LrndTheHardWay is offline
LrndTheHardWay is on a distinguished road
I went and bought a bench grinder and wire wheel just for cleaning up bolt threads
97 Limited with 310k
LrndTheHardWay is offline   Reply With QuoteReply With Quote
bolts , engine , pump , removed , water
Engine locked up, but didn't throw a rod? Timing belt? RunnerPDX 3rd gen T4Rs 22 12-28-2023 02:40 PM
2001 4Runner Battery Hold Down Bolt Size andyo 3rd gen T4Rs 9 06-26-2023 07:08 PM
Speedo/odometer first didn't work, now go to max. Engine doesn't know what to do. wilbertd Classic T4Rs 9 07-05-2015 02:42 PM
How important is this bolt I lost? Jayzero911 3rd gen T4Rs 11 04-18-2014 12:11 AM
important question to fellow engine techs Donovansolis 3rd gen T4Rs 1 08-08-2010 07:31 PM
