Old 12-22-2024, 11:37 AM #1
ITWrencher's Avatar
ITWrencher ITWrencher is offline
Real Name: Mike M.
ITWrencher is on a distinguished road
ITWrencher's Avatar
Real Name: Mike M.
Scratching my head gasket..........
Looking for some constructive input on my current issue?
I've done a ton of work on our 2002 Sport it in the last year including the entire top half of the engine in June. The wife drives it and about a week ago she came home furious because it started running like dog crap on the way home. This after it running like a Swiss watch since June? I swapped out the #5 coil as that was the one that was misfiring. It started running on all cylinders again. I re-used the same spark plug in that cylinder after cleaning it. I took it for a drive and it now had a rough idle and I could smell coolant wafting off the crossover pipe connection when I revved the engine? I pulled it in to the garage last night and pulled all of the plugs. They all looked good except for the #5 plug which looked darker but it hadn't been run very long after being drenched in fuel due to the coil going bad. I put a pressure tester on the radiator last night and checked it this morning. It had dropped pressure by 2-3 psi? I turned the engine over using a starter button with the EFI relay removed and didn't get any coolant blowing out of the cylinders. I am going to do a compression test later today but at this point I am scratching my head. The machine shop that did the heads said there weren't any cracks found in the heads?
So I am wondering what to do? Obviously I need to do a compression test and possibly a leak down if the compression test is good. I am worried that maybe the heads are cracked but also wondering how that could be the case?
Mike M.
2002 Toyota 4Runner Sport
235K mi.......
ITWrencher is offline   Reply With QuoteReply With Quote
compression , engine , heads , running , test
Head Gasket or Cracked Head 02 4runner - Colorado any mechanics out there? vanderwiel 3rd gen T4Rs 9 09-26-2021 09:10 PM
2004 head gasket #6 (gasket treatments work?) ingrjc1 4th Gen T4Rs 7 12-01-2019 12:39 PM
welp i finally did after hours of reading and scratching my head rvg112 3rd gen T4Rs 7 03-17-2011 12:56 PM
i'm developing a bald spot from scratching my head (93 won't start) ericcduf Classic T4Rs 3 12-06-2010 10:53 PM
