Originally Posted by ITWrencher
Again as I stated previously I was a dealership tech for quite a few years so I do have the experience doing cylinder head jobs. The bolts were all torqued to the factory manual spec's (which I bought right after purchasing the vehicle). Torqued to spec and then the 2 90 degree turns spec in sequence. If it was a premature head gasket failure then I am betting it was due to crappy aftermarket Fel-Pro parts. I’ve read recently that the Fel-Pro parts have gone down the drain quality wise which is disappointing because they use to be the de facto standard. I’m looking at $1600 all in with 2 new reman heads from CHI and about $600 with no cylinder heads and just all OEM replacement parts. I have to do the brakes on my other newly purchased 2002 SR5 4Runner so the wife has something other than my F-250 which is ridiculously gas hungry. Once that is done I can rip into the Sport and also replace everything on the new acquisition a little at a time because it needs A LOT of love.
Ok.. So you were a dealership tech and you didn't know to use only OEM head gaskets.. I am just a hobby mechanic and I know better then that only because of 30 years of working on Toyotas) . ;-) All aftermarket parts qaulity are going to complete crap. Even oem quailty I think is dropping some.
I know they can be costly. However, now 6 months later you are in the same issue. A head gasket or head issue. Being you took it to a machine shop and they inspected redoing the heads. I would be really surprized if the head cracked but possible.
You probably got burnt on the feel pro gasket. This is why I try to stick with OEM gaskets if possible. I get it, but I learned this 25 years ago, its not worth it unless you want to do the jobs over and over again.
Would the dealership use a feel pro head gasket on a rebuilt head or would they use a OEM gasket? I really don't know the answer to this question. I would hope they used the OEM Gaskets. Granted, I am seeing a lot of aftermarket parts drop off at the dealership now when I buy my Toyota parts at the local dealership.
I am not trying to second guess your abilities nor give you a hard time. I am just giving opinions on what I would do and you asked what direction to go..:-)
I do have a 5VZ-FE complete engine setting here but it has a bad bad head gasket so its most likely baked from a PO mud bogging it. So I wouldn't trust those Heads. Engine ran but was really noisey hence why I replaced it with a spare engine I had with 160K on it.
You can also check with Josh Young how runs an used 3rd gen junk yard for parts. He is in the Pacific NorthWest and you can find him on Face Book messenger. He most likely have used heads that are good. Or maybe even be able to ship you an engine reasonably priced you can even hear running before he pulls it.
I hope this helps you. I cant tell you how many times I did this prior to 25 years ago...
Some parts you can get away with Aftermarket. Some parts we cant.
