Old 12-29-2024, 11:08 PM #1
brokedownwallet brokedownwallet is offline
brokedownwallet is on a distinguished road
Shuddering at very low speed turns
Some background, inner tie rod boot has been torn for at least a couple months now though the tear has been minor this whole time until today where it completely separated from the clamp. I just did my LBJs and my alignment is also noticeably off, possibly because my last alignment was done on worn LBJs.
Anyways, for the past couple months, I've noticed a shuddering when I've turned my car while parking. It's rapid and repetitive and it only is at a very specific angle, when I turn it farther it goes away. It's also only at very low speeds like 5mph as I back into and pull out of parking spots. It comes and goes but today it was the worst it's ever been, yet it only happens on tight but not fully locked turns. Could it be something as simple as tire rub even though I have a 2in lift and only run 265/70r17?
I'm thinking it's probably something worse than that as it's been more noticeable with my car being out of alignment after I swapped the LBJs. Does this sound like a tie rod problem? There wasn't much slop or play when I was pushing on them after reinstalling the LBS, the play was more the whole car on the jack moving rather than just at the wheel so it seems like rebooting the tie rod should be fine.
Could it maybe be a front diff problem? I just changed the trans fluid and it was nasty so thinking the previous owner may not have changed the T-Case and diff fluids but am wondering if that could cause this issue. Any insight would be appreciated, most of my research showed u-joint issues at higher speeds when I looked up shudders, but my Ujoints are fine.
brokedownwallet is offline   Reply With QuoteReply With Quote
Old 12-30-2024, 11:50 AM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
When you changed the transmission fluid. Did you change the strainer filter as well? Shuddering is bad.
Old 12-30-2024, 03:10 PM #3
I have a MT so don't think there is one. I've been thinking and I did just recently notice a rear axle leak that's pretty bad as the brake shoe is completely caked. Thinking the rear diff could be low on fluid, think it could be binding there? Going to fix that up this weekend and see where we get from there.
Old 12-31-2024, 04:08 PM #4
alumarine alumarine is offline
alumarine has a spectacular aura about alumarine has a spectacular aura about
I have to ask, you're not in 4wd are you?
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
Old 01-01-2025, 12:49 PM #5
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
You are correct just gear grease in the MT ( no filter.) If the rear diff is low it will do damage quickly. So the sooner that's fixed the better. I had to replace a 3rd member that the PO didn't fix the rear axle housing rust leak.
Old 01-06-2025, 12:42 AM #6
Ahaahah nope, actually working on fixing that right now. Got it figured out, it was actually tire rubbing, didn't think 265/70r17 would rub but it does on the front fender on the sidewall, but only at 3/4 turn, not full lock and only on the left side. Kind of stupid solution but glad it's nothing major
alignment , car , lbjs , rod , tie
Rumble Noise when Making Low Speed Turns Help. Milo 4th Gen T4Rs 22 11-26-2023 09:53 PM
Violent shaking/shuddering when coasting at speed BrandonF 3rd gen T4Rs 13 05-21-2014 04:19 PM
Drive Problems - Low Speed Tight Turns JohnnyQ7 4th Gen T4Rs 4 04-25-2011 01:51 PM
2010 4 Wheel Drive Problem with Sharp Low Speed Turns mrjonm 5th gen T4Rs 33 01-02-2011 04:07 PM
Quiet Rumble while in 4WD and Low Speed turns morphius909 Problems & Warranty Issues 4 10-17-2009 11:06 PM
