Old 01-05-2025, 03:32 PM #1
spinn spinn is offline
spinn is on a distinguished road
Front/Rear Suspension Lift Bilstein/OME setup
I have a 1996 SR5 that I bought a 2" lift kit from Wheelers Offroad. Just finished putting on the rear setup (5100 and 906) last night, and finishing up on the fronts (5100 and 881) right now.
I noticed that for the rears, the driver side still sat 0.5" lower than the passenger side, even after I switched the springs to their respective sides (which still had 0.5" difference). Is that normal?
For the front struts, the new setup didn't have the perches sitting outward, like my stock setup. Is that normal? I don't want to start driving on it if I'm going to need to have Wheeler's reset it.
spinn is offline   Reply With QuoteReply With Quote
Old 01-05-2025, 07:08 PM #2
that3rdgen that3rdgen is offline
that3rdgen is on a distinguished road
I don't have experience with lifts but from being around and hearing about others. I would say that is generally normal as almost all of the weight is on the driver's side. some people use spacers that I believe Ome sells that is like a 10mm spacer to go on the top of the rear spring. As for the shocks sometimes they get sent out backwards if I'm picturing in my head what your issue is. you just have to remove the top hat and spin it around I believe.
that3rdgen is offline   Reply With QuoteReply With Quote
Old 01-05-2025, 09:06 PM #3
Thanks! I'm probably going to get that spacer. After getting everything setup, the front wheel lip is 37" on both sides. The rear passenger is about 37-1/8", while the rear driver is about 36-3/4". I'll need to drive it around and see if it settles more.
Originally Posted by that3rdgen View Post
...you just have to remove the top hat and spin it around I believe.
Do you know what's the harm, if it's not turned around? Is it that easy to just move the top hat without unloading the compressed spring?
Old 01-06-2025, 05:39 PM #4
Contacted Wheelers, spacer is on backorder.
And, it doesn't matter where the coil pig tail ends and points, as long as the upper mounting plate and lower shock mount align with your vehicle.
Old 01-06-2025, 06:59 PM #5
2TH4IST's Avatar
2TH4IST 2TH4IST is offline
2TH4IST is a glorious beacon of light 2TH4IST is a glorious beacon of light 2TH4IST is a glorious beacon of light 2TH4IST is a glorious beacon of light 2TH4IST is a glorious beacon of light
2TH4IST's Avatar
@spinn
Here is the link to the rear trim packer, and it's in stock.
SRQ OME trim packer
16 bucks. Where I got mine from. Though it says to use on bottom of spring, it's not lol, it's put on top of the spring.
There's danger lurking around every corner, that's why I propose we make all of our buildings round.
I don't remember the time I was human that's why I don't understand anybody.
2TH4IST is offline   Reply With QuoteReply With Quote
Old 01-06-2025, 09:26 PM #6
Originally Posted by 2TH4IST View Post
@spinn
SRQ OME trim packer
Thanks! They're asking $12 for shipping. I'll check back after I've had it all settled.
Old 01-10-2025, 06:23 PM #7
Just make sure the knuckle clears the springs (on both sides!) at full droop through steering lock-to-lock. That's why the factory has the specified orientation - aftermarket springs are wound differently and often need a different orientation to have max (or even any) clearance.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
lift , normal , setup , side , wheelers
Bilstein B12 Spring Kit 1-1.5" Rear Suspension Lift - Reviews? pumacat24 5th gen T4Rs 11 05-20-2021 07:58 AM
One more Bilstein 5100 front lift, 0 rear lift question. Hugo Stiglitz 5th gen T4Rs 31 08-07-2020 10:29 PM
FS: Brand New Bilstein 5100 Front and Rear 0 - 2.5" Lift - $350 Alee27 For Sale: Suspension/Wheels/Tires 10 05-01-2018 10:00 PM
FS: 3rd Gen Tundra/Bilstein Front Setup (non-progressive) - WI - $120 1985taylor1925 For Sale: Suspension/Wheels/Tires 0 11-23-2014 08:18 PM
