Old 01-06-2025, 04:15 AM #1
stunt2 stunt2 is offline
stunt2 is on a distinguished road
Question Rear window defrost not working
Hi all. Searched through bunch of similar threads but found no solution.
Both tabs on my rear window defogger were broken off. Glued them with Permatex defogger repair kit. Now I got continuity between both tabs and also got 12V between them when connectors attached and defrost is on. But the grid still not gets warm, not any single line. Any ideas where to look for problem ?
stunt2 is offline   Reply With QuoteReply With Quote
Old 01-06-2025, 07:14 PM #2
Brew_rnr Brew_rnr is offline
Brew_rnr is on a distinguished road
Lift the gate up and check underneath the rubber boot at the top of the door. The wires in there have a tendency to sever from repeated opening and closing. That is my only thought on the matter.
Brew_rnr is offline   Reply With QuoteReply With Quote
Old 01-07-2025, 04:16 AM #3
As I've stated in the first post it does have current at the tabs when I turn defrost on. So broken wires couldn't be the problem
Old 01-07-2025, 06:48 AM #4
subzjc subzjc is offline
subzjc is on a distinguished road
You may be confusing available voltage with current.
Its seems you have power but no ground thus no current.
subzjc is offline   Reply With QuoteReply With Quote
Old 01-07-2025, 08:44 AM #5
I'm not a pro electic, just basic knowledge with multimeter, so can you elaborate bit more, what should I look for ?
With my understanding - push defrost button - got 12v between two tabs of the defroster. Turn the button off - got nothing between the tabs. It tells me that power goes at least untill the tabs. Power at tabs = defroster should work.
Or am I missing something ?
Talking about these tabs. They are glued and fixed now
These two wires shoud be positive and negative, right ? If one of them is broken, multimeter should not show any voltage between them, when switch is on
defogger , defrost , rear , tabs , window
Rear window wiper and rear defrost not working Ocracoke4ever 5th gen T4Rs 4 12-18-2024 12:22 PM
Mirror defrost possible without rear window defrost? GreenMountainOwl 5th gen T4Rs 5 11-28-2021 08:44 PM
Rear window, rear defrost, rear wiper not working BREX25 3rd gen T4Rs 14 06-23-2013 11:22 PM
Rear window,defrost and wiper not working Hiluxsurf 2409 3rd gen T4Rs 1 08-01-2012 03:48 AM
defrost not working on back right window panel Gecko123 4th Gen T4Rs 6 01-10-2011 06:12 PM
