Old 01-07-2025, 07:56 PM #1
whyzee125 whyzee125 is offline
whyzee125 will become famous soon enough
What is this wire?
Hey guys,
I was working under my 98 5 speed w/ e locker the other day and saw this. At first I thought it was an e brake cable so I looked closely as I was confused since my e brake works. I saw that my e brake is in fact connected as it should be.
I grabbed it and when it touched the axle, it sparked, telling me that it’s actually unterminated wiring. Now I have no dash lights or tail lights. I found the fuse for these in the engine bay fuse box but when I replace it, the new fuse immediately blows too.
What the heck did I do? What is this wiring? Thanks in advance!
https://i.imgur.com/XBeeJ5u.jpeg
https://i.imgur.com/ebHju9i.jpeg
Originally Posted by LittleCaesar View Post
At 5'7", I'd need a rocket up the wazoo to get in it.
But it looks good. I can't wait to see it being driven.
whyzee125 is offline   Reply With QuoteReply With Quote
Old 01-07-2025, 09:38 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Sadly I don't recognize it. Does it go to your e-locker? I am wondering if it goes to the switch on the locker so your dash light come on for the locker being enabled. Parking lights and dash Are tied together. When I was blowing tail fuse.. Mine was the trailer hitch parking light wire shorting. I would lose the parking lights and my dash lights burned the fuse (Tail)..
Old 01-07-2025, 09:42 PM #3
Thank you for the reply, Brillo! Come to think of it, while I was down there, I noticed my aftermarket trailer wiring is shredded where it goes through the grommet into the body. I'll check on that to see if that's the issue! I rarely tow so hadn't prioritized fixing that (it honestly may have been that way since I got the truck, not sure).
Good chance the wire in question does go to the e locker but the weird thing is, it lights up on the dash when the button is pressed. I haven't 100% confirmed it's working but it doesn't blink or anything, it appears to lock like it should. I'll do a little more investigation and report back!
Old 01-07-2025, 09:54 PM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
If that is the case.. Is the probably the trailer wire on the after market wiring. Mine pinched between the hitch and the bumper.. Would explain the dead short and blowing the tail fuse along with loosing the dash lights. If you check when the fuse blown your parking lights are maybe out as well. :-)
Old 01-08-2025, 08:36 AM #5
2TH4IST's Avatar
2TH4IST 2TH4IST is offline
2TH4IST is a name known to all 2TH4IST is a name known to all 2TH4IST is a name known to all 2TH4IST is a name known to all 2TH4IST is a name known to all 2TH4IST is a name known to all
2TH4IST's Avatar
That is the vent tube for the e-locker actuator. If you follow it back, it will go into the e-locker wiring. So if you extend the rear diff breather, you need to extend that breather as well.
Re the sparking, probably the frayed trailer wiring.
There's danger lurking around every corner, that's why I propose we make all of our buildings round.
I don't remember the time I was human that's why I don't understand anybody.
2TH4IST is offline   Reply With QuoteReply With Quote
Old 01-08-2025, 02:38 PM #6
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
on one of my 4runners, and my tundra I had similar issues, both related to the trailer wires. 4 runner had an aftermarket adapter that had gone bad, the tundra had a factory adapter that had gone bad.
and by adapter, I mean that little control box that plugs into factory wires for the lights
2002 tundra ac v8 4wd
1969 kharmann ghia
Old 01-08-2025, 05:50 PM #7
Well guys, I'm officially an idiot but I'm relieved I wasn't wrong that it didn't look like an electrical wire lol! Thank you all for the replies; my trailer wiring was super shredded where it comes through the body grommet. I just removed the whole harness for now, replaced the fuse and all is well. I'll order a new harness and make sure it's better insulated so it doesn't shred again
Thank you all so much.
brake , found , fuse , lights , wiring
Adapting a 3-wire gear driven VSS to a 2-wire electronic VSS harness? derekwilliams345 3rd gen T4Rs 10 01-11-2021 02:11 PM
Help, need to tab speed wire and ign wire behind dash Lawrence_Liang 5th gen T4Rs 5 01-19-2018 07:54 PM
Cigarette lighter wire tap - wire location? Nashvegas34 3rd gen T4Rs 7 03-03-2012 10:52 PM
How to wire speakers? Directly from amp or back to HU through stock speaker wire Woody17 Engines / Suspension / Wheels / Tires / Audio / Accessories 14 04-18-2009 07:36 PM
