Old 01-08-2025, 09:26 AM #1
Sir_LR Sir_LR is offline
Sir_LR is on a distinguished road
No power when accelerating and tries to shut off after slowing down
My 4Runner has been acting weird lately it痴 running ok then I take it out and it has like no power whatsoever when I知 trying to get up to speed it does slowly accelerate but not as much as before and after that stutter in acceleration if I try to slow down to stop the engine rpm drops to below 500 and stalls the engine occasionally. If I restart the engine it drives fine for a while and then does it again. I just got another engine put in it so I知 going to be doing maintenance like plugs what else should I look for. The fuel filter is 2 years old. Could a timing belt on its way out cause this? Any help appreciated
Sir_LR is offline   Reply With QuoteReply With Quote
Old 01-08-2025, 11:58 AM #2
I will upload a video later
Old 01-08-2025, 02:06 PM #3
Twisted Sid's Avatar
Twisted Sid Twisted Sid is offline
Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about
No codes?
I'd start with vacuum leak testing
'99 4Runner SR5: 5VZ, 2wd, AT, 400k+ club
'94 Pickup: 2wd, 22RE, 5spd, (3RZ swap in progress)
Front: Total Chaos Uniball Kit, Fox 2.5 8'' coilover
Rear: Deaver F67 Leaf Springs, Fox 2.0 14'' Reservoir Shocks, E-locker Axle 4.88 Gears 33x10.5 BFG ATs
Twisted Sid is offline   Reply With QuoteReply With Quote
Old 01-08-2025, 07:57 PM #4
spartacus's Avatar
spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of
spartacus's Avatar
Originally Posted by Sir_LR View Post
My 4Runner has been acting weird lately it’s running ok then I take it out and it has like no power whatsoever when I’m trying to get up to speed it does slowly accelerate but not as much as before and after that stutter in acceleration if I try to slow down to stop the engine rpm drops to below 500 and stalls the engine occasionally. If I restart the engine it drives fine for a while and then does it again. I just got another engine put in it so I’m going to be doing maintenance like plugs what else should I look for. The fuel filter is 2 years old. Could a timing belt on its way out cause this? Any help appreciated
What year. How many miles on the motor? Any codes? Plugs wires. Clean maf, clean throttle body and timing belt might help.
Edit: A new Pcv valve and tps sensor could help.
Old 01-08-2025, 08:56 PM #5
It痴 a 2000 and I cleaned the maf replaced pcv the engine has 220k km on it and currently have timing belt on order and plugs and wires.
Old 01-08-2025, 09:02 PM #6
https://drive.google.com/file/d/19KV...w?usp=drivesdk
Old 01-09-2025, 01:24 AM #7
Hungryhawk Hungryhawk is offline
Hungryhawk will become famous soon enough
An idea to see what result reveals.
I assume you are in drive"D". Does it act same in S4?
Have you turned off VSC and see if any difference?
My 2cents
Hungryhawk is offline   Reply With QuoteReply With Quote
Old 01-09-2025, 10:48 AM #8
Ibrad Ibrad is offline
Ibrad is on a distinguished road
A stretched timing belt would not be resolved by restarting. Did this start occurring right after the motor swap? If so it may be a sensor related issue caused by the computer receiving the wrong signsl after calling for sensor input. When input is received it goes wonky then on restart it happens all over again. If it's this scenario codes should be present. More information is needed.
Ibrad is offline   Reply With QuoteReply With Quote
Old 01-09-2025, 12:02 PM #9
My 2cents
My truck does not have s4 or vsc
Old 01-09-2025, 12:04 PM #10
It痴 been over a year since installing the engine I just don稚 know what maintenance history it has. I知 hoping to do some simple maintenance and fix it like plugs wires timing belt and clean the iac. Could this be caused by a fuel pump not sending enough fuel occasionally or is that not possible. Thanks for all the input
Old 01-09-2025, 12:05 PM #11
There痴 no codes showing at all
Old 01-10-2025, 10:33 AM #12
A faulty fuel pump could be possible. Could hook a fuel pressure gauge to it and see what it shows. How long after shutting off and starting again do the symptoms come back?
Old 01-10-2025, 10:44 AM #13
After shutting it off and starting sometimes it wouldn't even come back like it did yesterday but occasionally it does. I got the IAC gasket on order and I'm going to clean that out first and go from there with plugs and timing belt. Ill test fuel pump pressure while I'm at it, will report back with any findings
Old 01-13-2025, 12:17 PM #14
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a name known to all TheDurk is a name known to all TheDurk is a name known to all TheDurk is a name known to all TheDurk is a name known to all TheDurk is a name known to all
TheDurk's Avatar
The runs fine and then goes wimp is characteristic of a defect that is linked to the switch over from open loop to closed loop operation. In my case, a TB body clean was what it took, but it could br AF, MAF, or anything in that loop. Definitely not fuel pump, timing belt or anything else not in that loop.
My Backyard Frame Swap
Old Today, 05:43 PM #15
Update: it was indeed something to do with the tb since I took it apart cleaned the iac and reinstalled and cleaned the maf. The iac was super gummed up with carbon.now it runs great and idles amazing thanks for all the advice.
engine , fine , i知 , power , put
Loss of power when accelerating RUNNINIT Problems & Warranty Issues 33 02-05-2025 04:10 PM
Seized caliper slowing car down when accelerating Lolaya 4th Gen T4Rs 17 04-17-2023 01:36 AM
No power when accelerating, possible head gasket/water pump? roguestriker Classic T4Rs 3 08-23-2011 11:45 PM
Slowing down the rust ROT commostud Classic T4Rs 2 10-05-2010 06:52 AM
V6 Towing Problem - Loss of power when accelerating gonittanylions Problems & Warranty Issues 2 04-17-2008 06:40 AM
