Old 01-08-2025, 02:36 PM #1
1sam16 1sam16 is offline
1sam16 is on a distinguished road
Steering issue...
Hello!
I’m having a power steering issue with my 2002 4Runner/275,000. Just replaced the power steering pump- pressure line- and the steering rack. As I’ve been driving the past few days the truck won’t steer correctly- you point it in a direction and it stays going in that direction. Thought it might be an alignment issue but I just had it in the shop and it is still driving the same. Thought the PS pump might have been defective so I bought/installed another... no change. Feels like the pump isn't sending enough pressure- I'm getting about half the steering assist I normally have with this truck. I guess the new steering rack could be defective? Have any of you had a similar problem?
Thanks for your help!
1sam16 is offline   Reply With QuoteReply With Quote
Old 01-08-2025, 03:43 PM #2
2TH4IST's Avatar
2TH4IST 2TH4IST is offline
2TH4IST is a name known to all 2TH4IST is a name known to all 2TH4IST is a name known to all 2TH4IST is a name known to all 2TH4IST is a name known to all 2TH4IST is a name known to all
2TH4IST's Avatar
Hmm odd. Have you bleed the rack? Jack up the front and slowly turn the wheels left and right with engine off. Check for air bubbles. Otherwise might be a bad rack, or bad castor on the alignment. Do you have the alignment printout?
There's danger lurking around every corner, that's why I propose we make all of our buildings round.
I don't remember the time I was human that's why I don't understand anybody.
2TH4IST is offline   Reply With QuoteReply With Quote
Old 01-08-2025, 06:42 PM #3
spartacus's Avatar
spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of
spartacus's Avatar
Wheels on the ground takes a while to bleed the system . Lifting the truck and turning lock to lock has been easier for me to bleed the air out. Front wheels camber?
Old 01-08-2025, 07:55 PM #4
Camber and caster were frozen/un-adjustable by firestone but did not change when when I replaced the steering rack PS pump etc. Thanks for the advice I'll try jacking it up and moving the wheel lock to lock several times with engine off.
Steering issue...-img_0363-jpg
Old 01-08-2025, 07:57 PM #5
Thank you- will do!
Old 01-08-2025, 08:01 PM #6
GhostRing's Avatar
GhostRing GhostRing is offline
GhostRing is a jewel in the rough GhostRing is a jewel in the rough GhostRing is a jewel in the rough GhostRing is a jewel in the rough
GhostRing's Avatar
By those numbers, isn't your caster practically backwards?
Would that not explain the tendency to just keep tracking
on it's last trajectory rather than return-to-center?
I mean, yeah that's maybe a little exaggerated, but I'd say at least
bleed the system properly, get a sawzall, and get those cam adjusters
back under control.
Build Etc...
If it ain't broke, fix it 'til it is.
GhostRing is offline   Reply With QuoteReply With Quote
Old 01-08-2025, 08:29 PM #7
thank you- was just online looking at the process of replacing those. this truck runs great- would like to see her break 300,000
Old 01-08-2025, 08:40 PM #8
GhostRing's Avatar
GhostRing's Avatar
Also, is it lifted a bunch?
That practically-zero caster seems like a big susp. lift
without any UCA correction for the new ride height.
Build Etc...
Old 01-08-2025, 09:34 PM #9
2 inch lift
Steering issue...-img_4894-jpeg
Old 01-08-2025, 10:00 PM #10
2TH4IST's Avatar
2TH4IST's Avatar
As ghostring said, replace those cam bolts, and get it re-aligned. And possibly look into front upper arms (they are pricy) but give some correction for caster.
defective , direction , driving , issue , steering
Steering issue help 52577 4th Gen T4Rs 19 02-02-2021 06:32 PM
Cause of Steering Issue(s)? Knollie81 4th Gen T4Rs 18 06-25-2017 04:22 PM
Steering issue? Jeluthadamaja 4th Gen T4Rs 5 09-07-2013 03:53 PM
93' Steering Issue!! bosmob Classic T4Rs 10 02-19-2010 07:21 PM
Steering Issue jac100 Classic T4Rs 4 01-11-2010 04:40 PM
