Old 01-16-2025, 06:46 PM #1
Calloway Calloway is offline
Calloway is on a distinguished road
What did I do now?? No start HELP (SOLVED)
So truck has been running fine. I was trying to tighten the power steering belt due to a squeak.
Since I was working on the truck I decided to put on a new replacement air hose. It’s the large hose(very small section held by 2 clamps at each end) that goes from the throttle body to the air intake silencer.
I had used duct tape around the end that went to the air intake silencer since there was a leak. That short term solution had been working for a few years.
I did disconnect the air filter box to give me more room to access the power steering belt adjuster. And I did disconnect a few vacuum lines and unplugged an electrical connection to lift the air filter box up.
Now the truck won’t start. Started fine before I touched anything today. I get a P1300 code now.
Any help would be appreciated.
Calloway is offline   Reply With QuoteReply With Quote
Old 01-16-2025, 07:13 PM #2
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
You didn't post what year or engine but maybe the following will help.
I found an old topic on Tacoma World on a Tacoma that had the same code, he found a bad ground wire connection to the igniter, you may have accidentally pull the ground wire and it lost connection.
1999 Prerunner 2.7L no start P1300 SOLVED | Tacoma World
2004 Limited V8
Old 01-16-2025, 07:16 PM #3
2TH4IST's Avatar
2TH4IST 2TH4IST is offline
2TH4IST is a name known to all 2TH4IST is a name known to all 2TH4IST is a name known to all 2TH4IST is a name known to all 2TH4IST is a name known to all 2TH4IST is a name known to all
2TH4IST's Avatar
I'd double check that you got everything reconnected correctly. By any chance did you unplug the ignitor? Sometimes these plugs can be a pain to plug back in.
There's danger lurking around every corner, that's why I propose we make all of our buildings round.
I don't remember the time I was human that's why I don't understand anybody.
2TH4IST is offline   Reply With QuoteReply With Quote
Old 01-16-2025, 07:30 PM #4
Riceye Riceye is offline
Riceye will become famous soon enough Riceye will become famous soon enough
That electrical connector was likely for the air flow sensor. That may be your problem.
_________
2000 SR5 five speed. Everything works, even the antenna. No special mods; It's my canoe, kayak and dog hauler/winter beater.
I find that things usually go well right up until the moment they don't.
Riceye is offline   Reply With QuoteReply With Quote
Old 01-18-2025, 07:27 AM #5
Thanks for the replies everyone. Sorry was getting dark and on a family trip.
I’ll recheck connectors again when I’m back. I’m hoping I just didn’t reconnect that one plug I removed well enough.
Will keep you posted.
Old 01-20-2025, 01:23 PM #6
So I got back today and check all the wires and they seemed fine.
So truck was running fine before I touched the ISR to change that small piece. The reason I changed it was I believe there was a vacuum leak so I duct taped that piece bc the car wouldn’t start. Similar to what’s happening now.
The only other part I touched was tightening the power steering belt which I don’t think affected anything.
And lastly the accelerator seems to be on the floor. Not sure if it’s something that affects this no start issue.
Thanks again!!!
Old 01-20-2025, 03:25 PM #7
Thanks again!!!
If the throttle is held full-open, it is a 'clear-flood' mode for the ECU. It won't start with the pedal all the way down (really, the throttle body open all the way). Make sure the throttle moves freely by hand in the engine bay...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 01-21-2025, 10:09 AM #8
Here are some pics I took. Just curious if anyone sees anything.
My next step is to take out the air box and intake resonator and try and retrace my steps.
What did I do now?? No start  HELP (SOLVED)-img_3698-jpg  What did I do now?? No start  HELP (SOLVED)-img_3696-jpg  What did I do now?? No start  HELP (SOLVED)-img_3697-jpg  What did I do now?? No start  HELP (SOLVED)-img_3695-jpg  What did I do now?? No start  HELP (SOLVED)-img_3694-jpg  What did I do now?? No start  HELP (SOLVED)-img_3693-jpg
Old 01-22-2025, 09:23 AM #9
So started taking everything apart last night in the freezing cold and looked the wire connections. The MAF connector looked fine then I worked my way down to the ignition module. I started tugging on the plugs with wires and the brown one on the end just came out. I guess I tugged on the air filter box a little too much causing this. See pic below.
I pushed the brown wire in, and she fired up. So still need a permanent fix and ordered a new replacement wire. Will have to take the connector apart and push the old one out.
Thanks again for everyone's help!
What did I do now?? No start  HELP (SOLVED)-img_3693-edit-jpg
Old 01-22-2025, 09:44 AM #10
Real Name: Skip
Real Name: Skip
That's great you found the problem, I suspected you pulled on a wire a bit too hard during your work, that brown wire is most likely the ground wire for the igniter thus causing P1300 code as mentioned in the link I posted.
2004 Limited V8
Old 01-22-2025, 04:06 PM #11
New igniter connectors and pigtails are available from various vendors if those parts are damaged.
Good luck!
air , disconnect , end , power , truck
22RE Cold Start - Delayed Start - Exhaustive Troubleshooting pinemind Classic T4Rs 17 09-18-2021 07:38 PM
Runner won't start, relay makes noise but no start hakunamatata 3rd gen T4Rs 22 02-25-2020 03:11 PM
2018 TRD OR install aftermarket Push to Start & Remote Start? Aggie2015 5th gen T4Rs 0 09-06-2018 04:30 PM
RFID Keyless Entry, Push Button Start and Remote Start BFLAN 5th gen T4Rs 41 04-17-2012 09:36 PM
2000 4runner wont start without clutch start cancle jmcgahran 3rd gen T4Rs 3 08-29-2011 12:27 PM
