Old 01-28-2025, 10:21 PM #1
Wasatch Rebel Wasatch Rebel is offline
Wasatch Rebel is on a distinguished road
2000 with vibration issues
A couple of months ago I had noticed a vibration coming from my front end, or at least it seemed like it. Since I was planning to buy new tires in January, I sped up the purchase thinking that the vibration may be coming from the old tires being out of balance etc. The vibration issue has continued with the new tires despite three balancing attempts, so I'm thinking it's something else. Here are the complet symptoms as far as I can explain them.
1) The vibration is sporadic, meaning it isn't happening all the time. I have mostly noticed it at freeway speeds, but also occasionally lower speeds.
2) Today I heard and felt almost a "click" or "clunk" when the vibration was going on and it immediately stopped. It was almost like it was the clunk of going into gear, but this rig has a standard transmission--not an automatic.
3) I'm wondering if it could be brake related as I have been having my ABS dash light come on, plus, I have been noticing a little sponginess from the brake pedal occasionally.
4) I recently had a tie rod end replaced and no change from that at all.
My mechanic can't look at it until a week from tomorrow. Any ideas on what's causing this from my description?
Wasatch Rebel is offline   Reply With QuoteReply With Quote
Old 01-29-2025, 02:17 PM #2
nissanh nissanh is offline
nissanh is a jewel in the rough nissanh is a jewel in the rough nissanh is a jewel in the rough
Check for any worn out U-joints. If bad, install OEM only.. other brands are junk.
1990 3L Diesel Hilux LN 106; 1973 Ford Cortina XL
1992 4AFE Toyota Sprinter AE 91 (aka Geo Prizm)
1997 5vzfe 4Runner 4x4 (aka Hilux Surf)
2000 2uzfe 100 Series Land Cruiser
2021 Tacoma TRD Off-Road 4x4 6-speed
Old 01-29-2025, 02:33 PM #3
spartacus's Avatar
spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of
spartacus's Avatar
Check the u joints and play in the dive shaft.
Old 01-29-2025, 03:28 PM #4
2TH4IST's Avatar
2TH4IST 2TH4IST is offline
2TH4IST is a name known to all 2TH4IST is a name known to all 2TH4IST is a name known to all 2TH4IST is a name known to all 2TH4IST is a name known to all 2TH4IST is a name known to all
2TH4IST's Avatar
Also check the slip joint for play up and down and twisting as it can cause clunking. Check the double cardon joint too, it has 2 u-joints and a cv joint thingy in the center.
I had a high speed vibration 65mph+ and clunk accelerating after a complete stop. Ended up replacing the driveshaft w/tom woods unit. Vibration went away.
There's danger lurking around every corner, that's why I propose we make all of our buildings round.
I don't remember the time I was human that's why I don't understand anybody.
2TH4IST is offline   Reply With QuoteReply With Quote
Old 01-29-2025, 05:05 PM #5
InfernoShade InfernoShade is offline
InfernoShade is on a distinguished road
Check the wheel bearings and ABS sensors since worn bearings can cause vibrations and a faulty ABS sensor might explain the light and spongy brakes. Also inspect the driveshaft and U joints for play.
InfernoShade is offline   Reply With QuoteReply With Quote
brake , speeds , thinking , tires , vibration
Vibration Issues McJuju 3rd gen T4Rs 1 02-04-2015 06:44 PM
3rd Gen Vibration/Brake issues Chabbymeister 3rd gen T4Rs 4 09-23-2013 05:15 PM
3rd Gen Vibration/Brake issues Chabbymeister Classic T4Rs 2 09-22-2013 08:05 PM
vibration issues Rwperlaki 3rd gen T4Rs 3 03-27-2012 09:16 PM
A couple vibration issues hamdog 4th Gen T4Rs 2 03-04-2012 10:40 PM
