Old 02-07-2025, 08:51 PM #16
Spiker Engineering's Avatar
Spiker Engineering Spiker Engineering is offline
official vendor
Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of
official vendor
Yeah, it's easy to get hung up on semantics, as that thread on IH8MUD illustrates .
But if Seiken sells a booster that is identical to what I would get from Toyota, who cares if it's "OEM" or not? Just like if the Duralast box in your example contained a genuine Denso part, do I care what the box says? Or are you saying that there is something different inside the Seiken Bendix unit from the Toyota Bendix unit?
High Lift Hood Struts | Ultragauge/Scangauge Mounts | Phone Mounts
Custom 3rd Gen 4Runner products | 100% designed, fabricated, and assembled in the USA
https://spikerengineering.com
Spiker Engineering is offline   Reply With QuoteReply With Quote
Old 02-07-2025, 09:49 PM #17
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
IH8MUD is big on semantics. But the Toyota parts system and terminology might as well be a study in itself too. But the statement of Seiken not being OEM is true. As far as if the Seiken unit is different inside, no idea. Seems like a waste of manufacturing resources for a relatively low volume product.
Old 02-07-2025, 10:23 PM #18
2TH4IST's Avatar
2TH4IST 2TH4IST is offline
2TH4IST is a name known to all 2TH4IST is a name known to all 2TH4IST is a name known to all 2TH4IST is a name known to all 2TH4IST is a name known to all 2TH4IST is a name known to all
2TH4IST's Avatar
Like I just bought BCA/NTN boxed front wheel bearings, open box and they are indeed koyo at half the cost!
There's danger lurking around every corner, that's why I propose we make all of our buildings round.
I don't remember the time I was human that's why I don't understand anybody.
2TH4IST is offline   Reply With QuoteReply With Quote
Old 02-08-2025, 03:11 PM #19
GhostRing's Avatar
GhostRing GhostRing is offline
GhostRing is a jewel in the rough GhostRing is a jewel in the rough GhostRing is a jewel in the rough GhostRing is a jewel in the rough
GhostRing's Avatar
Ugh.
So my booster hunt continues....
I went cheap on the 3 Mirrors model and am not happy with the performance. (big surprise)
The return window closes today, so I am sending it back. Original going back in for now.
So I am now looking for a semi-reasonable replacement. Is Impex similar to Amayama or such?
It's my first time hearing of it. I want to get something quality - at least as close to OEM as I can muster.
Build Etc...
If it ain't broke, fix it 'til it is.
GhostRing is offline   Reply With QuoteReply With Quote
Old 02-08-2025, 03:40 PM #20
official vendor
official vendor
Originally Posted by GhostRing View Post
Ugh.
I'll keep you posted on Impex. I've never used them before but according to IH8MUD folks they're legit., just like Amayama (whom I've used tons). They are showing the booster at $140 less than Amayama.
Old 02-10-2025, 02:53 PM #21
nissanh nissanh is offline
nissanh is a jewel in the rough nissanh is a jewel in the rough nissanh is a jewel in the rough
Yes, impex is legit. I am on ih8 too but always purchased from partsouq.
You can rebuild a brake booster. The leak may be at the booster/master pump interface. There is a seal (behind the metal lock ring) which you can replace even without removing the booster. I have done that but first check the leak is there. If you open up the booster, you can clean and reassemble everything together.
1990 3L Diesel Hilux LN 106; 1973 Ford Cortina XL
1992 4AFE Toyota Sprinter AE 91 (aka Geo Prizm)
1997 5vzfe 4Runner 4x4 (aka Hilux Surf)
2000 2uzfe 100 Series Land Cruiser
2021 Tacoma TRD Off-Road 4x4 6-speed
Old 03-16-2025, 01:37 PM #22
official vendor
official vendor
I received the booster from Impex, so that worked out well. Even came with a new check valve. A lot cheaper than from other sources, including Amayama.
Old 03-20-2025, 11:00 AM #23
But the quality is not as OEM Toyota boxed Koyo bearings. How do I know.. been there and seen it.
Old 03-20-2025, 06:06 PM #24
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
That's a W, for you..:-)
Old 03-20-2025, 06:24 PM #25
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Yes, lots of times the Toyota OEM part vs the OEM Mfg can be different. Really depends on the mfg though. Aisin is the exact same part with the toyota logo ground off that cast on the water pumps.
What going to happen is Toyota will discontinue the bearings soon. Due to the age of these rigs. I seen this for years after 20 years lots of parts will get discontinue as they run out of the parts. This is really normal for Toyota as 25 years for most parts start disappearing. Its not cost effective to have the parts available forever. So when they are no longer available OEM. We be sourcing OEM mfg parts to replace them.
I am seeing a trend though that some models of Toyota are having a 3rd party work with Toyota mfgs to remfg parts to the Toyota spec they originally are. The downside is they will be 3 to 4x as much as the oem parts were because of what was involved. Seems to right now be the land cruisers, supras and a few other lines... Not the 4 Runners, Which is kinda surprising because the 4runners have a following just like the other ones do.
I am also surprised Toyota doesn't have a vintage part section of the company that just specializes in those parts for over 25 years old. As they would have all the contacts and mfgs at their disposal and the mfg wouldn't care.. They mfg it if it worth their time.. :-)
Old 03-20-2025, 08:35 PM #26
T4R2014's Avatar
T4R2014's Avatar
Spend some time on IH8MUD. The best way to keep OEM parts in production is to buy them. Toyota and its suppliers have put in a lot of investment into legacy parts production recently. Just as an example you can buy a brand new OEM engine harness for a 95-97 FZJ80 again. Yazaki moved tooling for legacy applications to a new plant dedicated to this in Vietnam. Keeps prices down and production going. You can even get Aisin window regulators with motors for 3rd gens now too.
FAQ - 1995-1997 1FZ-FE FZJ80 OBD2 Main Engine Wiring Harness Connector Information | Page 6 | IH8MUD Forum
Old 03-20-2025, 08:52 PM #27
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Yes. I seen a switch as of late.... In the past this was not heard of. So its definitely changing. I suspect we see legacy parts that were gone return which is a very great news..
Another source is GR HERITAGE PARTS | GR | TOYOTA GAZOO Racing
Old 03-20-2025, 11:42 PM #28
infamousRNR's Avatar
infamousRNR infamousRNR is offline
infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light
Did I miss the link to this item somewhere in this thread?...
1998 Desert Dune Toyota 4runner Limited 4x4 w/ factory e-locker
2000 BLACK Toyota 4runner Limited 4x4 w/ factory e-locker Build Thread
2002 Thundercloud Metalic Toyota 4runner Limited 4x4
Build Thread
infamousRNR is offline   Reply With QuoteReply With Quote
Old 03-21-2025, 09:52 AM #29
official vendor
official vendor
Originally Posted by infamousRNR View Post
Did I miss the link to this item somewhere in this thread?....
Hey Sean, here you go - 44610-3D700 TOYOTA , 446103D700 New parts search — IMPEX JAPAN
Old 03-22-2025, 02:36 AM #30
dang, that is a pricey little bugger......
Build Thread
boosters , branded , oem , seiken , toyota
Hard Brake Pedal During Panic Stops - Brake Booster? Friday88 3rd gen T4Rs 24 04-24-2024 12:14 AM
WTB - 99 2wd Brake Booster ICD For Sale: T4R Items 0 08-30-2021 12:15 AM
anyone ever mess up a brake booster by changing brake pads? jluu6r 3rd gen T4Rs 19 12-12-2019 05:01 PM
Brake Booster? MtnLlama 3rd gen T4Rs 10 10-16-2014 09:59 PM
Brake booster? smithTR4 3rd gen T4Rs 8 09-02-2013 12:35 PM
