Old 02-11-2025, 05:15 PM #1
Ernest1863's Avatar
Ernest1863 Ernest1863 is offline
Ernest1863 is on a distinguished road
Ernest1863's Avatar
A/C Troubleshooting
Hi All!
Sold my 03 a few years ago but I’m back in the game fixing up a 99 sr5 v6 4x4. One of the issues I’d like to fix by summer is the A/C. The compressor clutch never clutches so I can’t add coolant and it never blows cool. The A/C button is backlit but does not light up when pressed. I’m not sure where to alligator clip to test the compressor and I don’t want to parts cannon it but it feels like I should start with the switch. Does this feel like it’s the switch to y’all or would yall more suspect a pressure sensor or relay?
Restomodding/faulting a ‘99 sr5 v6 4x4
Previously owned 2003 sr5 v8
War Damn Eagle
Ernest1863 is offline   Reply With QuoteReply With Quote
Old 02-11-2025, 05:32 PM #2
How are the system pressures? The compressor won't engage if there is no refrigerant. If it is out, it will turn on once you start adding refrigerant... You'll want some dye to find the leak, but make sure you don't use anything with a 'stop-leak' in it.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 02-11-2025, 06:46 PM #3
2TH4IST's Avatar
2TH4IST 2TH4IST is offline
2TH4IST is a name known to all 2TH4IST is a name known to all 2TH4IST is a name known to all 2TH4IST is a name known to all 2TH4IST is a name known to all 2TH4IST is a name known to all
2TH4IST's Avatar
Exactly what phattyduck said. No freon, compressor won't turn on. 2 things to do, invest in basic ac gear, a gauge manifold, basic vacuum pump, thermometer, freon cans and ac oil.
Honestly unless your going to be doing lots of ac work it's cheaper to just take it to a ac shop and have it checked. Then diy the repair (that is if there is a freon leak).
There's danger lurking around every corner, that's why I propose we make all of our buildings round.
I don't remember the time I was human that's why I don't understand anybody.
2TH4IST is offline   Reply With QuoteReply With Quote
Old 02-16-2025, 08:01 PM #4
Ernest1863's Avatar
Ernest1863's Avatar
Cool, thanks both! Yea was wondering about if it’d be worth investing in the testing gear. Good thought on the diagnosis at a shop and diy repair. I’ll likely do that. Thanks again!
Edit: just for curiosity’s sake, shouldn’t the A/C light still light up or at least blink when turned on if the pressure is off and tripping a pressure sensor?
War Damn Eagle
Old 02-18-2025, 02:48 PM #5
The AC light should come on, based on the diagrams (some older Toyotas were able to turn off or blink the AC light to show errors, so I had to check). Make sure the blower fan is running, since that must be on to run the AC.
Old 02-18-2025, 06:45 PM #6
2TH4IST's Avatar
2TH4IST's Avatar
Also, check to see if they pulled the fuse. If they did, DO NOT put a fuse in until you check to make sure the compressor isn't seized. You can turn the clutch by hand, engine off (very front of the compressor, circled in red). If it rotates, usually a little resistance, it should be good and you can put the fuse in, of course if that's what they did.
A/C Troubleshooting-screenshot_20250218-145052_duckduckgo-jpg
Old 02-20-2025, 12:35 AM #7
Ernest1863's Avatar
Ernest1863's Avatar
Fuse was the first thing I replaced. I’ll try turning the compressor by hand tomorrow. What happens if is seized and it runs? Trash the compressor?
The blower is working fine. Heat is great haha
War Damn Eagle
Old 02-20-2025, 10:46 AM #8
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
If your compressor is seized. Replace it.. I had one start to freeze a month ago and I pulled the AC fuse until spring.
Like other stated if the coolant too low or non left the compressor will not engage.
Do you have gauges or a way to check the low side of the refrigerate to see if anything is there?
Those diy kits that have a hose with gauge would work. Just snap it onto the cold side and see if you have any psi in the system.
If zero.. You probably have a leak somewhere.
Old 02-20-2025, 12:47 PM #9
96RedRunner's Avatar
Real Name: Mark
96RedRunner is a splendid one to behold 96RedRunner is a splendid one to behold 96RedRunner is a splendid one to behold 96RedRunner is a splendid one to behold 96RedRunner is a splendid one to behold 96RedRunner is a splendid one to behold
Real Name: Mark
Good info been passed along for troubleshooting. Local parts store rental is best route to take
for equipment to do job.
When it comes to charging system with freon 2 12oz cans or 1 24oz can puts charge weight
in the plus minus range of factory specs for charge.
And with the age of system change the filter/drier it can bite you in the azz.
96RedRunner limited 4x4 5VZ auto not stock 374k miles totaled 2018.
2001 limited 4x4 5VZ auto work in progress not stock.
2011 Audi S5 Prestige 4.2 V8 6 spd. MT not stock.
Old 02-20-2025, 01:24 PM #10
2TH4IST's Avatar
2TH4IST's Avatar
If the compressor is seized and the clutch engages, either the belt will snap or the pulley/clutch will snap off the compressor, which can do nasty damage.
Old 02-20-2025, 11:42 PM #11
Ernest1863's Avatar
Ernest1863's Avatar
Thanks all!
Tried out the compressor clutch today and it turns pretty easily.
It may be a week or so before I can do the rental gear and do some testing. This weekend I already have the front brake pads slated (first time doing brakes) and have limited time during the week.
In the meantime I’m going to watch Chris fix’s AC recharge video I suppose.
Sounds more and more like a leak ran it dry. Would y’all try to find it yourselves or just take it to a shop if it’s got 0 pressure?
War Damn Eagle
Old 02-21-2025, 02:09 PM #12
Take a look at all the fittings (o-ring locations) and the condenser (physical damage) to see if you can spot the leak. If it is a large one, it will have oil residue in the area. Not foolproof, but it is free...
Old 02-22-2025, 12:06 PM #13
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
You can jumper the 2 pin AC pressure switch by the firewall passenger side to test compressor clutch, Receiver drier must be replaced when empty or opened to atmosphere for any length of time, usual cause of leak is the evaporator under the dash so you will also need a expansion valve if that is the case, the FSM has the volume of PAG oil that is to be added to each component replaced. I've had to do this job twice now on both my 97 and 99, it is DIY, evaporator comes out easily from under dash, if it is the condenser you are laughing, but you'll still need receiver drier and to vacuum the system down to boil/remove the water from the system and a gauge set. A O-ring and schrader valve kit is handy to have in stock aswell.
Malcolm99 is offline   Reply With QuoteReply With Quote
a/c , compressor , i’m , sensor , switch
Troubleshooting vsc off mod benztech82 4th Gen T4Rs 1 01-02-2021 09:36 PM
4wd troubleshooting fochtup1 3rd gen T4Rs 12 05-05-2018 09:50 AM
Troubleshooting help arduckhntr 3rd gen T4Rs 5 10-28-2014 08:44 AM
Troubleshooting.. CapnRoo 3rd gen T4Rs 7 06-09-2013 08:24 PM
TroubleShooting Help Please! TwoLeftShoes Classic T4Rs 2 12-13-2011 12:05 AM
