Old 03-10-2025, 07:53 AM #1
XPY's Avatar
XPY XPY is offline
XPY is on a distinguished road
XPY XPY is offline
XPY's Avatar
Drivers side power door lock
I have a 1999 3rd Gen 4Runner SR5.
The driver side door lock is acting up. Keyless entry works fine; door locks unlocks, the main key works fine, door locks unlocks. So it’s not the door actuator. The issue seems to be the driver’s side door control panel switch, it will unlock the door but is acting up when I try to lock the door, it only works intermittently.
So my thoughts are; there’s a short in the wiring somewhere on the locking side, or the actuator under the button for the driver’s side door control panel is the problem.
I removed the drivers side control panel, took it apart, was surprised there was no corrosion, considering the water that comes through the windows when it rains because of the trucks design, I cleaned the entire unit, contacts etc. but the problem persists, any thoughts on how to test the signal from it?
Been a while since I've asked for advice, there seems to be a tendency to get replies completely sidetracked off the issue.
XPY is offline   Reply With QuoteReply With Quote
Old 03-10-2025, 09:00 AM #2
Atomic_Dog Atomic_Dog is offline
Atomic_Dog is on a distinguished road
Is there any reason not to consider replacing the switch? Seems more likely than an intermittent open in the wiring. I've never had that switch apart to see if the part that moves the contacts could wear down to the point of being too short. Jumping the switch contacts would be the most definitive test as to which direction the problem was in. Sorry if I misunderstood your post.
2001 SR5 130k miles
Atomic_Dog is offline   Reply With QuoteReply With Quote
Old 03-10-2025, 02:16 PM #3
Along with the switch, it could be the wiring in between the door and body.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 03-10-2025, 08:27 PM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Thats mostly where it gets me.. Even more noticeable when raining or really damp too.. :-)
control , door , panel , side , works
drivers side rear door with power locks gtojimbo 3rd gen T4Rs 7 11-05-2024 03:33 AM
Drivers side rear door power window stopped working- NYRunner 5th gen T4Rs 6 07-16-2023 09:30 PM
Replacing drivers side door handle/lock Redcat 3rd gen T4Rs 9 02-26-2019 12:15 AM
Drivers side power door won't lock/unlock txt4r 3rd gen T4Rs 29 10-18-2017 08:47 PM
FS: Power Door Lock Actuator with Lock Latch - rear passenger side T4RTX For Sale: T4R Items 4 06-26-2014 02:58 PM
