Old 03-12-2025, 10:32 PM #1
Pyral's Avatar
Pyral Pyral is offline
Real Name: N/A
Pyral has a spectacular aura about Pyral has a spectacular aura about Pyral has a spectacular aura about
Pyral's Avatar
Real Name: N/A
Leaking brake line because of brake flare
My brake line is leaking fluid at the fittings between the soft lines at the front. There is some coating that appears to be coming off. How can I clean these up so that they'll be fluid tight?
The hoses I used were OEM from a reputable source, I'm confident it isn't the hoses fault.
Leaking brake line because of brake flare-img_6261-jpg  Leaking brake line because of brake flare-img_6262-jpg  Leaking brake line because of brake flare-img_6259-jpg
1998 4runner 2.7 manual
Pyral is offline   Reply With QuoteReply With Quote
Old 03-13-2025, 02:12 PM #2
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
bump
Old 03-13-2025, 04:31 PM #3
Real Name: Skip
Real Name: Skip
If the line is easy to replace I would do so, otherwise you would need to cut it and reflare with the proper flaring tool/die set it if it's long enough.
2004 Limited V8
Old 03-13-2025, 06:36 PM #4
wtfdissux2 wtfdissux2 is offline
Real Name: Chuck
wtfdissux2 is on a distinguished road
Real Name: Chuck
I would replace the fitting and re flare. unless the fluid is on the treaded side of fitting then try to snug it down more or replace hose. it sucks but have had issues with new parts right out of the box before
wtfdissux2 is offline   Reply With QuoteReply With Quote
Old 03-18-2025, 01:25 PM #5
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
I had someone replace the hard brake line from the caliper to the soft brake hose, fixed the problem. The part was only $15 from the dealer, if you bleed it yourself it's cheap to fix. I didn't have time to so it wasn't that cheap.
The new hose wasn't the problem. All I can say is don't overtighten the flare nuts, that could deform the flare.
brake , clean , fluid , leaking , line
Front hard brake line into caliper leaking - please help! smerhej 3rd gen T4Rs 15 05-21-2024 09:35 PM
Rear Passenger-side Brake line leaking, can't get to it 94KC4runner Classic T4Rs 8 08-20-2015 01:08 PM
e brake line too short? landcruiser e brake? D Farms 3rd gen T4Rs 0 05-25-2015 12:19 AM
Leaking drivers rear brake line repair Awdtsi42o Classic T4Rs 4 11-19-2011 09:34 AM
