Old 03-21-2025, 05:59 PM #1
RogueWaive RogueWaive is offline
RogueWaive is on a distinguished road
Mystery. Zero DC power. Minutes later, full power back and started like normal.
Good afternoon,
Daughter went to fire up her 2000 4Runner SR5 yesterday morning, came back in the house and said it wouldn't start. We sent her to school in Mom's Highlander. Mom went to try the 4Runner, said the electric door locks wouldn't work and no noise nor turnover when ignition attempted. Daughter reported same via text after she got to school.
So figuring our daughter must've left a light on, I grab the charger and head out to the driveway, open the door and the dome light comes on. I test the door locks and they function normally. Then the rig fires up like she has a brand new, OEM starter powered by a brand new pair of 1150CCA, fully charged AGMs.
The only thing that comes to mind is... there IS a negative disconnect on the battery (from when it was her grandpops' rig, that was no longer getting much use in his twilight years.) But I found it fully closed with no corrosion. All connections tight. And still... I wouldn't think a little corrosion would kill the entire 12V system... and a little dome light.
Obviously corrosion wasn't a problem because of all the cranking power that suddenly returned.
I would say maybe a fusible link could be loose or something? The only "jarring" to "fix" a bad connection would have been my dainty wife shutting the door after she confirmed it had no power.
Thoughts?
RogueWaive is offline   Reply With QuoteReply With Quote
Old 03-21-2025, 06:50 PM #2
JustTroItIn's Avatar
JustTroItIn JustTroItIn is offline
JustTroItIn is on a distinguished road
I recently had a similar issue. Had been driving for about an hour, and then made a quick stop. Had full power until I turned the ignition then everything went dark. I popped the hood to check connections, finding no issues. When I opened the door the dome light came back on and the truck started right up. My battery was pretty old so I replaced it, but not until the next day and two more starts later. The problem has not returned and it's been about a month.
2000 Limited w/ rear locker
-Dobinsons IMS, JBA UCA, Whiteline Bushings, TBU, Hidden Winch
2000 SR5 4WD Auto w/ J Shift
-Stock Beater
JustTroItIn is offline   Reply With QuoteReply With Quote
Old 03-21-2025, 06:57 PM #3
Yeah I'm not super in love with crippling problems that just fix themselves before I can diagnose them. Especially when it comes to my wife or daughter's car.
But thanks for chiming in. Sort of nice to hear I'm not the only one. I guess misery does love company.
Old 03-21-2025, 10:39 PM #4
I like to make sure mine struggle. Prepares them for life.
Yes, I'm kidding....a bit.
Good luck tracking it down. I'm doing the big 7 upgrade soon, and will be able to give her a better look over. I'll be watching this thread.
-Stock Beater
Old 03-22-2025, 01:02 AM #5
Hungryhawk Hungryhawk is offline
Hungryhawk will become famous soon enough
Two things come to mind:
1) a balky relay - does your model have a main relay?
2) does the ignition key have a security electronic chip in it? Were famly members using different keys? Their battery status?
Hungryhawk is offline   Reply With QuoteReply With Quote
Old 03-22-2025, 01:35 PM #6
No security chip. According to the Mrs., the door locks didn't work using the manual button on the inside door handle either.
I'll have to crack open that relay box.
Thanks!
Old 03-22-2025, 11:54 PM #7
pluton's Avatar
pluton pluton is online now
Real Name: Keith
pluton is a jewel in the rough pluton is a jewel in the rough pluton is a jewel in the rough
pluton's Avatar
Real Name: Keith
The relay idea seems promising. A note on corrosion at the battery: If it has a FLA battery, there can be invisible-to-the-eye corrosion between the battery post and terminal clamp. AGMs don't outgas sulfuric acis as FLAs do, so if it has an AGM that's probably not an issue. Doesn't hurt to wire brush the terminals and clamps every so often anyway.
pluton is online now   Reply With QuoteReply With Quote
Old 03-23-2025, 12:02 AM #8
Just an FLA.
Thank you. I will brush the terminals and clamps, but... have you ever heard of this causing my issue? i.e park the car in the driveway the night before just fine. Zero power the next morning. Then full power mysteriously returns, on its own, within minutes. And then no return of the problem for the next couple days and counting?
Old 03-24-2025, 01:18 AM #9
pluton's Avatar
Real Name: Keith
pluton's Avatar
Real Name: Keith
Just an FLA.
I have had invisible corrosion that caused random switching between full normal start and no start. Not exactly the same as 'full DC power-no DC power', but worth eliminating as a possible cause or contributor to cause.
Old 03-24-2025, 07:15 AM #10
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Everything dead. or everything low power mostly is at the terminals. Then all the sudden working without doing anything. Can be frustrating. If everything else has proper power levels and terminals not the issues. Next place is in the ignition system. Especially if your 180 to 250K with the original starter still in place. The contacts and brushes are warn out. Extremely common to act like that if the contacts are just about completely done.. If that is all good and it still randomly doesn't want to start. Check the ignition key contacts as they wear too but mostly a high mileage issue with the key contacts and a lot more on the rare side.
Its really a process of elimination until you find it. This is only ideas of what to be looking for. :-)
Old 03-24-2025, 08:18 PM #11
Thanks, but it wasn't ignition. There was zero power. No dome light. No power door locks. No noise or instrument lights when they turned the key. No nothing.
Several minutes later, everything was working and the starter spun the motor like it was a new unit for a Peterbuilt.
Frustrating indeed.
Old 03-25-2025, 01:04 PM #12
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Did you find the cause? As it will do it again until you do, probably when you least expect it too.
Old 03-26-2025, 03:07 PM #13
Yeah, believe me... that has been haunting me. As I mentioned earlier, I'm not a fan of crippling problems that just fix themselves before I can diagnose them.
No. I have not yet found the cause. I haven't had time to look into the relays yet. It's parked while my daughter is visiting family for spring break.
Old 03-26-2025, 04:31 PM #14
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Everything dead along with the dome circuit.. It has to be at the terminals. Sometimes its right at the crimp spots too.. Could even be as simple as dirty lead terminals. Thais a complete open circuit when that happens. Narrows it down to the end point the terminals on the battery and the immediate area of ...;-)
Old 03-26-2025, 04:57 PM #15
So to go from working normally the afternoon before when parked...
to zero power the next morning...
to full starting power several minutes later... nor major jarring... just the wife closing the door... is terminals?
Seems odd to me. I've seen diminished starting power from corroded terminals. But never full... to zero... to magically full again like this.
But I'll check and clean the terminals. Never hurts.
corrosion , daughter , door , light , power
1-2 Minutes truck loses some power 3rd Gen :hunter: DirtyDoctor 3rd gen T4Rs 15 01-18-2024 10:16 AM
Please Help: Extreme Loss of Power (@ 30% full power) mattkc16 5th gen T4Rs 33 05-17-2017 09:43 PM
Is it normal for power steering to squeal at full lock? 5VZFE 3rd gen T4Rs 7 02-04-2015 01:22 AM
power outlets not producing full charging power outgolfin0 4th Gen T4Rs 9 10-14-2013 12:39 PM
Normal ? Vsc no power at all in snow on slight grade NOT ME OR SOMEBODY 3rd gen T4Rs 12 02-13-2011 01:07 PM
