Old 02-05-2008, 04:28 PM #1
jranger35 jranger35 is offline
jranger35 is an unknown quantity at this point
'98 Battery Drain
I've got a new battery and the test shows battery good, starter good, alternator good. It seems like a drain to me. In the mornings the engine slowly cranks a couple of times like the battery is discharged (and sometimes it won't even crank--I have to wait a few seconds and try again), but then it fires up and runs fine. A mechanic buddy told me to disconnect the ground wire from the battery every night. Being as that's totally ghetto, I figured I'd ask the trusty 'ol 4runner forum if:
1. Anybody has had a similar problem (and how you resolved it).
2. The most frequent culprits of battery drain.
3. How I would test different components for a drain.
Thanks in advance.
jranger35 is offline   Reply With QuoteReply With Quote
Old 02-05-2008, 05:42 PM #2
techno's Avatar
techno techno is offline
techno is a jewel in the rough techno is a jewel in the rough techno is a jewel in the rough
techno's Avatar
Re: '98 Battery Drain
Yes. On a new Chev Blazer. No one could ever find the problem and car was replaced under lemon law.
Not really sure but I would guess lights, ignition coils, accessories...?
Pull fuses one at a time and see if one makes a difference, and go from there.
techno is offline   Reply With QuoteReply With Quote
Old 02-05-2008, 08:49 PM #3
KellyJ's Avatar
KellyJ KellyJ is offline
KellyJ is on a distinguished road
KellyJ's Avatar
Could be some of the wires that are for the rear light hatch. Our '96 had this issue, where some of the wires somehow shorted out because rain got in past the grommets, which made the battery drain.
'02 Limited 4WD
Stuff:OME 3"|ARB Tacoma|Light Racing UCA's|Savage KO sliders|285/75 Terra Grapplers|TRD catback|TRD wires|Brembo'd|VVME 4300K HID|LightForce 170|Exterior LEDs||Inside: Infinity Comps/Kicker/Nuvi625WT|Uniden 520XL|15% tint|Full LED swap|Backup camera
Pending Install:LC80 wheels,OME 883 and LC 8 wraps,panhard drop
KellyJ is offline   Reply With QuoteReply With Quote
Old 02-06-2008, 09:37 AM #4
I think we can rule out battery drain. I disconnected the ground cable last night, and this morning it acted in exactly the same way. Any thoughts???? This is really stumping me.
Old 02-06-2008, 08:15 PM #5
I've read a lot of posts about a similar (if not the same) problem, and the starter contacts seem to be the culprit. I've ordered some, and I'll post the results when I'm done next week. In the meantime, I thought I'd ask if any 4runner owners have done this procedure and their thoughts and experiences on it, or if anybody knows where I can get a detailed pic by pic walkthrough. That, and what's the best access point to get the starter out?
Old 02-18-2008, 05:00 PM #6
Starter Contacts
Yep, it was the starter contacts. If you ever need to do this, all you need to do on a 3rd Gen. 4runner is:
--Before anything, remove ground cable from battery.
1. Remove the front passenger tire.
2. Remove the clips holding on the splash guard, remove splash guard.
3. Remove the upper half of the transmission fluid dipstick (you'll need to wiggle it to get it out, wd-40 to get it back in).
4. Remove the two bolts holding the break lines in place (one on outer side of frame, one on inner side).
5. Remove power cable from starter.
6. Remove two 14mm bolts on the bellhousing that are holding the starter in place (the really #@*#! FUN part).
7. Remove plastic power clip.
8. Wiggle out, replace contacts and plunger, and throw it back in!
Some pics of the contacts:
Photobucket
Photobucket
Photobucket
Photobucket
Old 03-10-2008, 08:12 PM #7
swanics swanics is offline
swanics is an unknown quantity at this point
Can you just clean the contacts?
swanics is offline   Reply With QuoteReply With Quote
Old 03-10-2008, 08:32 PM #8
If you want to do the job twice you could. Look at the groove created in the dirty contact--that is not supposed to be there. Compare it to the top one, and you realize that the plunger, over time, has created that groove from constant yet mild grinding. The contacts need to be replaced when this happens because the plunger no longer comes into the contact with the contact.
Old 03-10-2008, 08:45 PM #9
2000se 2000se is offline
2000se is on a distinguished road
Fantastic Find!!
jranger35 - That is the determination factor kickin in!! Great work. And thanks for the follow up post..pictures and all...
That kind of post is what helps massively when we do a search!!
2000se is offline   Reply With QuoteReply With Quote
Old 03-10-2008, 08:59 PM #10
Thanks 2000se. That's why I did it-- because if you have your 4runner long enough, you'll have to do this (at least if you want to save some cash) and it's easier if you can pinpoint the problem and then understand the steps to fix it.
One thing that I want to add. You can get the top 14mm bolt out of the bellhousing with only a 4" extension, socket and socket wrench (but it's tight). I had this crazy apparatus made up of a u-joint, 10" extension, 4" extension, and a pivoting head socket. It was crazy, but worked, yet I did the installation with what is described above.
Old 03-11-2008, 12:27 PM #11
This really helps me out. I have a similar problem that seems to come and go. I've cleaned the battery contacts, tested the battery fluid, and now it sounds like I'll have to pop the starter out. I'm thinking the cranking amps might be low..... I want to rule out the battery before I go through the hassel of removing the starter.
The basic problem is that I'll turn the key and the starter will halfway turn over or just click (usually just click). Before I cleaned the battery contacts the car started poorly with more frequency. A good example is, click, click, click, start. It's like there is no chance and then boom, it starts right up. My very first thought was a crappy wire somewhere in the ignition. Mainly because my the backlight on my temp control would go on and off.
How much did the contacts cost? Where did you order them? How long did they take to arrive? Oh yea, I have a 98 4Runner LE
Old 03-11-2008, 01:22 PM #12
Pretty much sounds like my problem, but I won't make any guarantees. Mine is the same year, a 98. Google Toyota 4runner starter contacts and take your pick. They cost me $20 plus $5 for shipping. I couldn't find them at any of the major auto parts stores (hmmm, $200 for a new starter or $20 for the parts to fix it?). Good luck!
Old 03-11-2008, 08:10 PM #13
nserpa9248's Avatar
nserpa9248 nserpa9248 is offline
nserpa9248 is on a distinguished road
nserpa9248's Avatar
good job on figuring out the problem and fixing it! Thanks for the write-up
I think im going to do this just as a preventative maintnence thing when i do my "big 3" upgrade since ill already be down there.
99' 4runner SR5
ISR Mod
Deckplate Mod
BFG All Terrain T/A K/O
Python 990 SST Remote Start + Alarm (W/goodies)
Optima Yellow Top
Pioneer DEH-P5900IB
Polk Momo 6.5" Component Speakers
Polk DB 4" Coaxil Speakers
Polk C400.4 4-Channel Amplifier
Polk C500.1 Mono Amplifier
2 12" Kicker CVR Subwoofers
Tsunami Wiring
Tsunami 2Farad Capacitor
nserpa9248 is offline   Reply With QuoteReply With Quote
Huge Parasitic Battery Drain Problem pax 3rd gen T4Rs 36 07-04-2019 05:19 PM
Strange battery drain Red Classic T4Rs 4 09-02-2009 09:33 AM
Keeping your battery charged in cold weather Thai Maintenance/Detailing 0 02-10-2003 08:09 PM
Avoiding Dead Batteries! Thai Maintenance/Detailing 1 12-06-2002 08:40 PM
