Old 02-11-2008, 09:21 PM #1
wm69 wm69 is offline
wm69 is an unknown quantity at this point
Tranny fluid change...which fluid?
Ok, I've been reading thread after thread on the flush vs non flush here. I even contacted Toyota directly and they said "drain and fill" on my 01 4runner, 116K (drain and fill was done at 30, 60, 90K). I'm thinking I will do what I've done on my Honda (Hondas do NOT like flushing) and drain, fill, drive around for a few days, drain, fill, drive around a few day, and then drain, fill one more time. I know that doesn't get all new fluid in there, but it would get the fluid MOSTLY new.
I DO intend to drop the pan on the first drain/fill and clean it out, and I'm kinda sorta thinking about disconnecting the tranny line and putting all new fluid in there like the writeup on yotatech, but my main question is.....which fluid should I use? I know Hondas are pretty much ONLY supposed to use Honda fluid if you don't want your tranny to explode, but what about 4runners?
Is there a special "toyota" tranny fluid or can I use mobil1 or Castrol (I've always used Castrol GTX oil in my vehicles)?
If I were to use, say, Catrol ATF, would it mix ok with what is in there, or do I really need to do a flush and put all new stuff in there?
wm69 is offline   Reply With QuoteReply With Quote
Old 02-12-2008, 12:50 AM #2
4BangerRunner's Avatar
4BangerRunner 4BangerRunner is offline
4BangerRunner is an unknown quantity at this point
I just had mine done today ..."Drain and Fill" ..ONLY...if they've got over 100,000 on them, that's all Toyota says to do ....Mine is a '99 4 Banger with 124,000+ on it...
DEXRON III is what the Toyota dealership used...
Labor, parts, fluids, supplies all came to $42.75
Will have my wife's done on Friday - she's driving a '98 V6 with 144,000+ on it...
4BangerRunner is offline   Reply With QuoteReply With Quote
Old 02-12-2008, 01:00 AM #3
So does the brand of Dexron matter? Will any DEXRON III fluid be compatible with any other DEXRON III fluid?
Old 02-12-2008, 01:11 AM #4
I don't think there's a compatibility problem - the invoice on mine says "bulk", so obviously the dealership buys it by the barrel - as long as it says DEXRON III, I wouldn't be too concerned.
1987 4runner transfer case fluid change 02runner4 Classic T4Rs 0 10-09-2009 05:21 PM
Brake fluid maintenance Thai Maintenance/Detailing 4 06-02-2006 04:07 AM
92 tranny fluid leaking into transfer case s_to_the_g Problems & Warranty Issues 1 09-07-2005 09:08 PM
2 questions--throttle postion sensor, and trans fluid change naseeb Maintenance/Detailing 0 09-01-2005 10:13 AM
What is the proper way to check your automatic tranny fluid ? MudbogPete Maintenance/Detailing 3 11-28-2003 01:54 AM
