02-16-2008, 01:36 PM
Auto Trans reliable in 3rd gen 4runners?
Just curious. Ive been looking for manual trans trucks but, they are hard to come by..If I get an auto should I be worried about anything? Any horror stories or bad history on the auto slulsh box?
Thanks
Harold
ForSale-98 4runner Black/tan leather,power, 5spd, elocker
02-17-2008, 09:26 PM
Mine doesn't fully engage every time I accelerate. It sometimes will rev up like it's in neutral and won't engage for a split second. Has been doing it off and on since I bought it. I imagine it needs attention, probably a flush and fluid/filter change. I intend to trade it in tomorrow, but I have put almost 25k on mine and it has done this every once in a while for the whole time I have had it.
02-17-2008, 10:40 PM
i have a 96 with over 200K miles, still good!
this tranny has been pussed so hard! we go hunting in the truck, and have pulled a few people out of some holes.
my auto is a good auto
Never ask a girl if shes sick, she might not be wearing any make up. - lets just say she went storming off.
Never tell your wife she looks tired, they tend to hit and say that means she looks ugly. (weird logic i know)
02-17-2008, 11:26 PM
Miles/ condition/ history of your trans 2damtns?
25k on top of what? It couldnt have only 25k on the trans..?
Harold
02-17-2008, 11:43 PM
I bought mine with 99k on the clock, and now it has almost 123k, so I have put almost 25k on it while I have owned it. The dealer supposedly serviced everything before I bought it, and I assumed they would have changed the tranny fluid/filter. I now suspect they did nothing for the tranny (my first time dealing with a dealer). It was my original erroneous thought which led me to not have it looked at when it started. It actually did OK for a month or two, and only started when the weather got really cold, so I thought maybe the fluid wasn't circulating well when it got too cold. Anyway, I had AAMCO transmissions look at it 2 or 3 times, and they always said it was fine, threw no codes, etc. When I had it in getting serviced the other day, they commented on it but didn't know what was causing it, but recommended a tranny flush and filter change. It needs quite a bit of other stuff done to it too, so I am just going to trade it in and be done with it.
As for the tranny itself, it seems to pull fine other than the intermittent episodes I've described. It pulls well on hills, does fine at low speeds, everything like that. I haven't towed much of anything with it, just pulled my brother's car a couple feet up the road to a wide spot once. The lights never have come on, really no other indicator of it being a problem.
02-18-2008, 10:42 AM
used vehicle. Hard to tell what it was used for off road or towing before you got it. Issues with cold fluid could be fixed with the correct fluid or fresh fluid exchange usually. Its possible they used a standard replacement fluid that was not designed for the 4runner?
Anyone else that knows the history of thier transhad issues?
Harold
02-18-2008, 11:10 AM
I bought my 02 2WD 4Runner with 101k on it about a year and a half ago. It has 123k on it now. I am the second owner on it and it has over 4 pages of service records from Toyota dealerships. I had it flushed again at roughly 118k and have had no problems out of it. I have towed various things from a street bike to a tool box to even a 93 Civic Hatch on a heavy ass double axle Uhaul trailer.
88 CRX DOHC Turbo - Mod list reads like a novel
73 Datsun 510 - SSS Side Drafts, Cam, Header, Exhaust (Under Restoration)
02 Toyota 4Runner 2WD SR5 - Front Skidplate, Deckplate Mod
02-18-2008, 12:23 PM
Some people with 01-02 autos have reported transmission failures (planetary gear) after 100k miles. Not sure if it's a defect, because it has not happened to too many owners. No TSB's yet. However, there are a TON of 4Runners, Tacomas and Tundras with the same auto transmissions that have been ABUSED with no problems.
I would make sure that the previous owner did not abuse the truck. That is the most important thing.
I have 93k on my 4Runner and I have no problems.
02-18-2008, 12:49 PM
Really? I didn't know anything about that. That worries me. Anything I should look for warning signs wise?
02-18-2008, 04:48 PM
96 with 230k still going strong with auto tranny.
2002 SR5 4WD
deckplate + ISR, Airlift 1000, OME 881/890, Goodyear Wrangler Duratrac 265/75/16C
Tundra 231mm Brakes - yes they DO fit the stock 5 spoke rims - Stubbs Welding HD-SKO sliders.
02-18-2008, 05:48 PM
Super Moderator
Super Moderator
My mom has almost 100k on her '99 Limited and I have 137k on mine and no issues with either trannies or pretty much anything else outside of both our axle seals being replaced by 100k.
2010 Lexus RX350
'99 4RUNNER Highlander SR5 4wd *Sold
02-18-2008, 11:43 PM
I have 180K on my automatic trasmission now. No problems, I have changed the filter and fluid at around 90k and I'm going to do it again as soon as the weather warms up.
21' SR5 Super White
13' SR5 Blizzard Pearl (traded)
99' Limited Desert Dune (sold)
67' Firebird 400
91' Sr5 Runner (totaled) R.I.P.
02-19-2008, 03:06 AM
Just look for abnormal operation of the tranny or weird noises. Most say that the transmission would screech for a week or so before it gave. Also note that this is from a forum where people beat the snot out of their trucks, so it might be blown out of proportion.
02-19-2008, 11:16 AM
My '98 has 76K miles. I flushed it at 70K. Transmission has never given me any issues, then again it better not at 76K lol.
'98 4Runner Limited 4x4
02-19-2008, 11:30 AM
Well I haven't had any problems so I hope I have a good one LOL
