03-13-2008, 06:24 PM
Finally Tundra 13WL brake upgrade...56k beware
Look what came in the mail!
I ordered the 199mm S13WE but after doing research, the 231mm 13WL seemed to be a better replacement.
TRD stickers
Stickers clear-coated on.
The old setup...You can see my Downey headers...oh yeah!
sorry camera phone...
remove the two bolts holding the caliper...
Look how much worn down the stock rotors were. The new Tundra rotors are way beefier.
Installed...
A close up.
The stopping power is amazing. After heavy braking there is no more brake fade.
1996 4runner Limited V6 4x4, Downey Headers with a custom Magnaflow exhaust w/o cats, Custom lowering kit w/ Eibach lowering springs, Addco front & rear sway bars, Energy Suspension greasable sway bar links, 22x9 TSW Black Rhino Keros Silver, 285/40R22 Falken tires, powder coated RED post-TSB Tundra S13WL 231mm calipers, D/S rotors, JDM Black headlamps and black clear corners, Clear bumper lights, LED rear tailights, Viper Alarm w/ Remote start and All window roll-down option, Billet grille
http://img257.imageshack.us/img257/3...turepicfn9.jpg
03-13-2008, 07:08 PM
Real Name: James
Real Name: James
SICK!!!!!!!!!!!!!!
1997 SR5 5spd
SS 1.2 - Deckplate - MT Classic II's
ISR - True Flow - Magnaflow - 285/75 BFG AT
03-13-2008, 08:02 PM
dam schon nice mods to your truck
where you order that stuff and what kinda damage it do?(money wise)
03-13-2008, 08:13 PM
a lot of conning and research for the cheapest price online. haha
03-14-2008, 12:36 AM
Nice... I'm also curious as to the $$ you put into the tundra brake upgrade. Good bye warped rotors and hello dashboard as ya slam on them brakes.
'96 4Runner SR5
V6 4WD
160K and counting
TJM-15 Silverstars
Hella 500 Tundra Brake Upgrade
03-14-2008, 03:34 AM
DAbrakes
Screw da BRAKES lemme buy your RIMS!!
VERY NICE!
But yeah, your setup looked so EZ!!!
Was it less than $500?
Also, what made you go with slotted/drilled? I thought everyone said stay away from that combo.
Now im confused.
I need some rotors BAD!! Dashboard is taking a beating so bad!!!
oh well...
Current: 1999 4runner Limited 2wd (Desert Trooper) 170k miles! - WIP!
- s13we brake upgrade
New: 2001 4runner SR5 2wd (Silver Surfer) 213k miles! - WIP (looking for engine)
New: 1999 4runner Limited 2wd (KiTT) 577k miles!!!!!!!! - WIP!
Sold: 2000 4runner Limited 2wd 220k miles (idiot! i know)
03-14-2008, 09:32 AM
Super Moderator
Super Moderator
I would'a just went with slotted and avoided any kind of crossdrilled since within 30k miles they will crack and I've yet to see a set not do that. Still a great setup over stock as 4Runners brakes are pretty weak.
2010 Lexus RX350
'99 4RUNNER Highlander SR5 4wd *Sold
03-14-2008, 10:00 AM
Real Name: Uhhh this is my real name
very nice look
those look outstanding.
Those calipers would not fit behind a 16 inch rim is that fair to say?
nice pictures thanks for posting them up
06 4th gen V8 4WD of course...
08 Honda Ridgeline RT
05 Scion xB-the toaster-daily driver
my Yota Fanatic photos are on Facebook- here is link:
http://www.facebook.com/album.php?ai...5&l=5795132731
03-14-2008, 01:07 PM
another one for the Tundra/Sequoia upgrade! I believe 16" after market wheel will fit. On stock wheels you can run wheel spacer or grind the inside down.
i am running on 16" Egale wheels with wheel spacer, since my tires blew out. This is how i know it fitted.
how much did you get your set for?
here is my break down for my set.
$130 for rotors and pads.
$100 for front and rear calipers for 06 Sequoia. (off ebay)
$30 for fluids (brake fluids and a Big Mac meal)
2 hrs of your life
equal to $260 and a brake well worth it.
03-14-2008, 02:01 PM
I thought there was a Tundra brake that fits within the stock 16" alloy rims. Is it the standard Tundra brakes, and not the TRD ones?
“Engineers don’t idle well.”
'99 Limited 4WD
Upgrades: BFG AT T/A KO 265/75/16, Husky floor liners, WeatherTech window deflectors, Silverstar Ultra headlights, TaskLED Dome lights, Red & White LED maplights, LED tails & 3rd brake light, 35% tinted front windows, TrueFlow air fliter, hardwired V1, Scion T1807 HU w/ Aux input, Masterflow MF1052 in rear side storage
Mods: Deckplate/ISR, independent fog light control, rear diff breather, constant hot 12v outlets, seat-mounted LED Maglite
03-14-2008, 04:13 PM
Originally posted by CO_FlyFisher
I thought there was a Tundra brake that fits wihtin the stock 16" alloy rims. Is it the standard Tundra brakes, and not the TRD ones?
Yes, the earlier Tundra calipers fit (199mm).
OP - Nice set of brakes. Hope it works out for you. IMO, a little overkill. I would've just went with the stock blank rotor set up, but at least they look nice.
BTW, does anybody even have 56k anymore? 56k warnings don't seem applicable now-a-days.
03-14-2008, 05:24 PM
2 hrs of your life
Did you say that you did a sequoia rear brake upgrade??
Here's my break down...
$130 on the D/S rotors (pair)
$260 Tundra 13WL Calipers
$30 Powder coated
$60 Hawk pads
As far as drilled vs slotted... i've had the D/S on all my vehicles and never had a problem with cracking...so never thought much of it.
56K...ya i know, it just sounded good. like...LOOK OUT!!
and a lot of hand cleaner...
03-14-2008, 05:59 PM
i am thinking of how to use it on the 4runner. but i am only using the front calipers right now.
03-16-2008, 12:43 AM
Real Name: Bryan
Real Name: Bryan
could you possibly spill the beans on where you found all this for the rest of us to find??
Millennium Silver 2001 4Runner SportR5lander
Photo Timeline - Solid Axle Club
All-Pro, Fox, Eibach, OME, Goodyear, Trail Gear, Yukon, Solo Fabworks, Marlin, TJM, Smittybilt, Front Range Offroad, Inchworm, Addco, Savage Offroad, B&M, Borla, Pioneer, Cobra
Northeast 4Runner Owners Association
03-17-2008, 05:29 PM
Ebay is your friend. Just take your time on putting it together. took me over 3 month to win a set. But if your stock breaks are still good then way rush.
