Old 03-21-2008, 09:28 PM #1
hvguy hvguy is offline
hvguy is an unknown quantity at this point
quick! just installed engine and need to prime fuel
I just got my engine together, and I need to prime the fuel system.
how would I go about doing this?
I googled it and nothing came up. And there are not any ports on the fuel rail to tap into
hvguy is offline   Reply With QuoteReply With Quote
Old 03-21-2008, 11:08 PM #2
toytech76 toytech76 is offline
toytech76 is an unknown quantity at this point
Why do you want to prime your fuel system? Personally when I put a motor together. I want to crank it for a little bit before I start it to build oil pressure. Just by cranking it the fuel pump will do its job and fill the lines. If you need to prime the system without cranking it, take a jumper wire and jump terminals B+ and Fp in the black diagnostics box under the hood
02 Tundra TRD Limited. 285/75/16 Goodyear Dura-Tracs, 16x8 ProComp 1079 alloys, Bilstein 5100's with extra 1/4 spacer on top, Camburg UCA's, 1.5" block in rear, Banks catback exhaust , DDM Tuning 5000K HID's, Factory LSD in rear
toytech76 is offline   Reply With QuoteReply With Quote
Old 03-21-2008, 11:50 PM #3
there isnt a connector for Fp, but I can hear the pump come on when I start cranking.
But still nothing.
all of the wires are connected.
any ideas?
Old 03-22-2008, 12:53 AM #4
correction-
i have fuel
got spark
but when I put the timing perfect- it sounds like there isnt any compression.
any idea? I just took the right valve cover of to make sure I aligned the cams right, and they are- both dots meet perfectly.
the head it torqued, and im stumped
Old 03-22-2008, 03:40 AM #5
sounds like a cam timing issue if it sounds like you have no compression
