If this is happening at idle for you, it's normal. Reason being is that the alternator isnt charging much, if at all, at anything below 1500 RPM. Once it gets above that you would see the output of the charging system be something in the neighborhood of 14 volts. It will vary from car to car depending on the design of the alternator but every car I've owned has done this
'02 4runner SR5 4wd - Sunfire Red Pearl
