LSD confussion
My '99 Runner has LSD differential. I've researched over the net how this differentials work. But my confusion is regarding what type of LSD the runner uses (vcs, torse, etc..). My other question is, does the LSD is permanent, meaning that is working al the time, or only when 4wd is enabled or low range?
The other question is, in this kind of truck with this lsd, what happens when you engage Lo Range, does powers splits 50/50 and uses 4wd or just transmits power to the rear wheels. I have a lot of confusion about this. I know that in Low range the truck multiplies it power, but what I don't know is if it uses 4wd while engaged and how this affects the LSD.
The last question is regarding Rear Locker, is this the same as LSD or is it different?
Could you guys help me out?
Thanks
JJ
4Runner '99 SR5
