No offense taken Ron. I need to take some pics of the plugs I pulled out of my 2001 for you to see though. Like I said, there is a huge difference in the amount of wear between the NGK and Denso plugs. I was a Toyota tech for about 10 years, and was certified as a Toyota master diagnostic tech when I left. I have seen this difference in wear on all the original plugs I pulled out of the 5VZ-FE in that time. That said, there is nothing wrong with the Denso's, and if I was still working at the dealer I would probably use them too. Kinda hard to beat an employee discount, and having them on hand when I needed them. The only difference between the NGK and Denso is the NGK will last a bit longer if they are both the same type of plug.
I still never figured out why there were different plugs in each bank.
