Old 10-08-2008, 09:38 AM #1
ScottDetroit ScottDetroit is offline
ScottDetroit is an unknown quantity at this point
Unhappy 2002 4Runner- VSC, Trac, Check Engine lights came on today
I have a 2002 4Runner with 109,000 miles on it. On the way to work this morning, the VSC, Trac, and Check Engine lights came on. I did the research on the site about the Zero Point Calibration. I've never replaced the 02 sensors- could this also be the cause? I'm driving to Chicago from Detroit thursday. Is this something I can 'handle' when I get back from my trip or should I not be driving that distance with these lights on and these systems 'shutdown'?
Thanks for any help or info,
ScottDetroit
ScottDetroit is offline   Reply With QuoteReply With Quote
Old 10-08-2008, 09:52 AM #2
Stick Figure's Avatar
Stick Figure Stick Figure is offline
Stick Figure will become famous soon enough
Re: 2002 4Runner- VSC, Trac, Check Engine lights came on today
O2 sensor code usually isn't enough to set off the trac control as well as the check engine light. I used to get this issue w/ my IS when it would throw a random misfire code when i would use my two step rev limiter to launch. You need to pull the code(s) and see what you are really dealing w/ before you decide to drive the truck or not.
Stick Figure is offline   Reply With QuoteReply With Quote
Old 10-08-2008, 11:05 AM #3
p nut p nut is offline
p nut is on a distinguished road
When the Check Engine Light goes off, the TRAC and VSC will always light up by default. It's a "safety feature" Toyota implemented. And yes, it does mean that you won't have the traction system, but it does NOT mean you can't drive it.
I'm sure it's the O2 sensor, and would definitely advise on getting it replaced as soon as possible, but if you HAVE to drive it, I doubt it will leave you stranded. You will notice a worse MPG, though.
p nut is offline   Reply With QuoteReply With Quote
Old 10-08-2008, 12:04 PM #4
I just drove it for lunch and all three lights are staying on- The VSC off, VSC trac, and the check engine light. So it 'could' be a bad 02 sensor? How can I get this checked out without going to teh dealer? Would Autozone be able to 'plug' inot my 4Runner's computer and spit out a code that will diagnose the problem?
Thanks a ton for the replies,
ScottDetroit
Old 10-08-2008, 01:05 PM #5
Yes, take it to Autozone or I believe Checker's does it, too. At 109k miles, it not uncommon for the O2 sensor to go out.
Old 10-08-2008, 01:45 PM #6
Rock Slide's Avatar
Rock Slide Rock Slide is offline
Rock Slide is on a distinguished road
Rock Slide's Avatar
x2 on pulling the codes. Most, if not all, auto parts stores will pull the code for you for free.
Can't say whether it's an 02 sensor not, but it could be.
I once had all my dash lights light up like you described...turns out my gas cap just wasn't as tight as it should have been.
2002 4Runner Sport 4WD
Headlight Adjustment
"Live life w/o Limits. Your imagination is not limited by time or distance, by logic or by scarcity. You can fill your imagination with whatever you choose."
Rock Slide is offline   Reply With QuoteReply With Quote
Old 10-08-2008, 04:33 PM #7
Went to Autozone-
this is what popped up on their little computer-
P0446 Evaporative Emission Control System Vent Control Circuit Malfunction
Now what do I do?
Thanks,
ScottDetroit
Old 10-09-2008, 09:46 AM #8
01t4rnr's Avatar
01t4rnr 01t4rnr is offline
01t4rnr is on a distinguished road
01t4rnr's Avatar
Originally posted by ScottDetroit
Went to Autozone-
Now what do I do?
Thanks,
ScottDetroit
either a valve or the entire canister assembly, the latter runs almost $300. I opted to just remove the check engine bulbs, wont hurt the performance. And yes im sure some of you are :jaw drop: but im not spending that much money unless its making my truck taller or faster. out of sight , out of mind
2001 4 Runner 4wd SR5 v6 auto. TRD Tundra coils,adj. Bilstein 5100's, 8 wrap LC coils, 15% tint, Hella 500's, Skyjacker Nitros, 285/75/16 Mud Dawgs, 16x10 rims, B&M 70268
01t4rnr is offline   Reply With QuoteReply With Quote
Old 10-09-2008, 09:47 AM #9
01t4rnr's Avatar
01t4rnr's Avatar
** could also be a loose gas cap , try tightening down and make sure it clicks a few times . unhook the negative battery cable and drive to see if it comes back on. Mine would go up to a week without a light but would keep coming back eventually
Old 10-09-2008, 05:34 PM #10
toy cruzr's Avatar
toy cruzr toy cruzr is offline
toy cruzr is an unknown quantity at this point
toy cruzr's Avatar
I had this happen to me when I replaced my stock air filter with a cold air intake I'd hit passing gear and all the same lights would fire off I'd disconnect the battery for a while and the lights would go off until the next time I hit passing gear. try cleaning your mas air sensor it's plugged in to the air intake tube it takes about ten min. and a bottle of sensor cleaner found at any auto parts store it costs about $5.00 every body should do this once and a while
2001 runner limited
Beige&silver
leather
front tint to match
AEM intake Flomaster70
Royal Purp axles&trans case
EBC rotors&pads
more to come
old truck 92 extd cab toy
lifted 22re 33's
toy cruzr is offline   Reply With QuoteReply With Quote
Old 10-09-2008, 06:53 PM #11
miniracer miniracer is offline
miniracer is an unknown quantity at this point
Personally I would blow the code out with a scanner and see if it comes back. Evap codes are intermittant frequently, and the problem may not be there now. Driving it with this code will not hurt it. Just be aware if you are driving in a situation where vsc or traction control could be activated that it is diabled when the lights are on.
Chris
miniracer is offline   Reply With QuoteReply With Quote
Old 03-09-2010, 07:48 PM #12
MICA4R's Avatar
MICA4R MICA4R is offline
MICA4R is on a distinguished road
MICA4R's Avatar
Please help with similar problem.
VSC RANDOMLY ACTIVATES~!
please click this thread...
http://www.toyota-4runner.org/proble...dry-roads.html
MICA4R is offline   Reply With QuoteReply With Quote
Old 03-10-2010, 02:04 AM #13
01sr54x4's Avatar
01sr54x4 01sr54x4 is offline
01sr54x4 is an unknown quantity at this point
01sr54x4's Avatar
I had the same code pop up on mine almost 5k ago... I had the light cleared by a buddy and it came back on. Tried the old negative terminal trick too, which cleared it, but again returned. I ended up putting a good thousand miles on it before deciding what to do and the light turned off on its own. It's possible that a small piece of charcoal from the canister gets caught in a valve, keeping it open. I'm not suggesting you do what I did, but driving it around for a while, a little harder than normal, seemed to work for me. Hasn't come back on to date.
2001 SR5 4X4 Thunder Cloud Metallic
265/70/16 Hankook DynaPro ATM
Passport 8500 X50, rusty bumpers and a check engine light on
01sr54x4 is offline   Reply With QuoteReply With Quote
Old 06-02-2012, 12:00 PM #14
jet_dr969 jet_dr969 is offline
jet_dr969 is on a distinguished road
Had a similar issue at 151K on my 2002 4Runner (P1135 code). The upstream sensor is pretty easy to change (Bosch P/N 13613) with a 12mm socket or wrench and going from underneath. Might be a good idea to soak the studs with a penetrant oil to facilitate the nut removal if you have any corrosion. If you have a decent digital multimeter you can check the old sensor prior to opening the new one to make sure it's the problem. The 2 black wires (heater circuit) should read about 12 ohms. In my case, the circuit was open (alas, the problem). You can also check out the oxygen sensor circuit (blue and white wires) using a propane torch and multimeter set to read DC volts. With the sensor cold, it should read 0 VDC. When heated with the propane torch it should put out 1 VDC. You have to get the sensor tip pretty hot (mine was cherry red) and it was putting out around 0.85 VDC. After 151K miles, that's pretty good in my opinion. The Bosch sensor runs around $190 at Autozone, but you can get it on Amazon for around $138. When reinstalling the new sensor use the anti-seize compound on the threaded studs and do not over-torque the nuts to allow for heat expansion! As always, be sure and disconnect the negative battery terminal prior to beginning any work - this also clears the code in the computer. All my engine indications cleared and haven't come back since. Good luck!
jet_dr969 is offline   Reply With QuoteReply With Quote
Old 08-09-2013, 09:38 AM #15
eliharrison56 eliharrison56 is offline
eliharrison56 is on a distinguished road
I have a 2002 4rubner sr5 230,000 miles and its 2wd today I was Backing out parking lot and check engine light came on, and it came on a long time ago and it was the o2 sensor, anyone have any ideas on why it came on?
eliharrison56 is offline   Reply With QuoteReply With Quote
2003 4Runner- VSC Trac/ Trac Off Lights Only coolvman83 Problems & Warranty Issues 13 10-30-2019 11:05 AM
VSC, Trac, and Check Engine Lights ncthomas 3rd gen T4Rs 3 03-10-2010 08:47 PM
VSC Trac , VSC Off and ABS lights ON.... fred98050 Maintenance/Detailing 1 09-14-2008 09:39 PM
VSC TRAC lights feloniousQ Maintenance/Detailing 0 03-03-2004 09:30 PM
Complete Information on 3rd Generation 4Runners Thai 3rd gen T4Rs 9 04-17-2003 01:10 PM
