Old 11-06-2008, 03:35 AM #1
dbg's Avatar
dbg dbg is offline
dbg is an unknown quantity at this point
dbg dbg is offline
dbg's Avatar
Spinning noise when clutch is pressed in idle gear
My 2000 4runner SR5 4WD is at ~106k now. Recently I kept making spinning noise whenever I pressed down clutch or between gear shifts. I know this noise is embarrassing when you drive stick. I barely can avoid making this noise in the past two weeks or so.
Is this a wear-out problem on the clutch? I read online and saw that a worn throw-out bearing could cause such a noise. What type of 'bad' driving habit could cause it? Or it is simply an aging issue?
-- 2000 SR5 4WD Radiant Red
dbg is offline   Reply With QuoteReply With Quote
Old 11-07-2008, 07:00 AM #2
drmorbius's Avatar
drmorbius drmorbius is offline
drmorbius is on a distinguished road
drmorbius's Avatar
Re: Spinning noise when clutch is pressed in idle gear
+1 on the throwout bearing. I would look at the clutch disc and pressure plate, and the flywheel surface while you are in there. Not at all unusual for these parts to be worn, especially if it has been driven hard. Also a good time to replace the plastic shifter piece on the trans.
Larry
"Monsters From the Id"
2004 SR5 V6 Titanium Metallic/Stone, Auto Dimming Compass Mirror, Valor Tip, Overhead Console W/HomeLink, Cargo Net, Michelin Cross Terrains, Added JBL Synthesis 10 speaker system 6/08, USA Spec PA-15 TOY Ipod Interface, Drivers Side Overhead Handle, Valvoline Synpower 5W-30, Mobil 1 75W-90, LEDs
drmorbius is offline   Reply With QuoteReply With Quote
Old 11-26-2008, 05:44 PM #3
dbg's Avatar
dbg dbg is offline
dbg dbg is offline
dbg's Avatar
Re: Re: Spinning noise when clutch is pressed in idle gear
Thanks for the advise!
I brought it into mechanics and changed clutch set which includes above parts for $700 (labor is about $450).
Right after the repair work, I can feel the clutch needs much lighter force to depress than it requires before the job. Sometimes the 4WD was not engaged but most of the times it works. Today, it is raining and the 4WD light will not turn on. No matter how I tried to engage H4 or L4. I brought it back to the shop. I was told it is a hard problem to fix and ask me to bring it back after the holidays. I hope this clutch job does not mess up with 4WD...
Old 11-29-2008, 08:47 PM #4
Sleddogg Sleddogg is offline
Sleddogg is an unknown quantity at this point
did you say that since it was raining, you wanted to put in in 4h?
Sleddogg is offline   Reply With QuoteReply With Quote
Old 11-30-2008, 03:04 AM #5
dbg's Avatar
dbg dbg is offline
dbg dbg is offline
dbg's Avatar
Correct. It was raining, but I cannot put into 4H. However, that evening, it works again. I could say it works for 1 out of 5 different times when I wanted 4H gear. Kinds of strange.
Old 11-30-2008, 04:27 PM #6
shootmymime's Avatar
shootmymime shootmymime is offline
shootmymime will become famous soon enough
Talking
sounds like you need a bigger hammer for persuasion... sorry im no help
Never ask a girl if shes sick, she might not be wearing any make up. - lets just say she went storming off.
Never tell your wife she looks tired, they tend to hit and say that means she looks ugly. (weird logic i know)
shootmymime is offline   Reply With QuoteReply With Quote
Old 11-30-2008, 07:43 PM #7
dbg's Avatar
dbg dbg is offline
dbg dbg is offline
dbg's Avatar
4WD light might not be turned on all the time
Thanks. I might try it myself - reading the "1996 to 2002 Toyota 4Runner Repair and Wiring Manuals" and will do it when I get a chance.
After reading, I suspected "ADD Actuator". ADD stands for "Automatic Disengaging Differential". Searched google and found these posts with similar symptoms as mine:
http://www.tundrasolutions.com/forum...d-working-not/
http://www.yotatech.com/f2/01-4runne...m-help-128924/
http://en.allexperts.com/q/Toyota-Re...runner-4X4.htm
In my case, 4WD light works from time to time though. I will read more on ADD now. Any comments?
5th Gen Rattle Noise newbie5thgen Problems & Warranty Issues 11 04-11-2011 10:38 PM
Noise noise noise skorpion 3rd gen T4Rs 6 12-05-2009 03:47 PM
transmission noise - was noise in reverse jmfranc 3rd gen T4Rs 2 07-07-2008 08:10 AM
clicking noise while spinning on ice Cubfan 3rd gen T4Rs 4 12-09-2007 07:37 PM
rattling noise tortex53 Classic T4Rs 0 09-25-2006 03:22 AM
