Old 11-11-2008, 10:06 PM #1
findlayjeff findlayjeff is offline
findlayjeff is an unknown quantity at this point
Angry Door Panels.........how Do They Come Off
i looked all over and once again no luck finding any info on any threads
findlayjeff is offline   Reply With QuoteReply With Quote
Old 11-11-2008, 11:33 PM #2
shootmymime's Avatar
shootmymime shootmymime is offline
shootmymime will become famous soon enough
unscrew the philips screw behind the door handle, take a flat head screw driver and pop off the back or front (i cant remember if you do it on the wrong side you will brake off a tab) of the power window switches, and disconnect the wires, with a few good tugs pull off the whole panel
and you should be finished,
Never ask a girl if shes sick, she might not be wearing any make up. - lets just say she went storming off.
Never tell your wife she looks tired, they tend to hit and say that means she looks ugly. (weird logic i know)
shootmymime is offline   Reply With QuoteReply With Quote
Old 11-12-2008, 12:48 AM #3
Stick Figure's Avatar
Stick Figure Stick Figure is offline
Stick Figure will become famous soon enough
you should be able to leave the window switch in and just reach behind the panel as its coming off and unplug the wires.
Stick Figure is offline   Reply With QuoteReply With Quote
Old 11-12-2008, 09:25 AM #4
anyone have a diagram
Old 11-12-2008, 09:26 PM #5
my speakers should be in on fri so i need to know please help
Old 11-12-2008, 10:54 PM #6
Rock Slide's Avatar
Rock Slide Rock Slide is offline
Rock Slide is on a distinguished road
Rock Slide's Avatar
Once you know how to take the door panels off, it's super easy. I've taken mine off several times before and you'd be surprised how easy it is.
This page maybe of some benenfit to you on the removal process:
http://www.4runners.org/writeups/sound/deaddoor.html
2002 4Runner Sport 4WD
Headlight Adjustment
"Live life w/o Limits. Your imagination is not limited by time or distance, by logic or by scarcity. You can fill your imagination with whatever you choose."
Rock Slide is offline   Reply With QuoteReply With Quote
Old 11-12-2008, 11:04 PM #7
yes that did help thank you when he refers to pns or htm what is that, where do you get it
Old 11-13-2008, 05:00 PM #8
Rock Slide's Avatar
Rock Slide's Avatar
Both pns and htm are different types of sound deadening material. PNS is just a universal term that stands for peel-n-stick. It's typically very pliable...which makes it very easy to mold over uneven surfaces. HTM however, is not as easy to mold. It's better suited for large flat areas such as the roof.
Here's Bob's full write up on his sound deadening install in case you have not seen it (it contains multiple pages): Click Me. And of course, here's his home page full of all types of write ups: Click Me too
I covered my entire floorboard and cargo area with PNS that I purchased from McMaster-Carr.com. Part # 9640T2. This is the same stuff Bob used in that door panel write up I posted earlier.
To see pictures of my own ound deadening install, check out Post # 5 of my build thread: Click Me. This stuff makes a huge difference in blocking out road noise. I just need to get around to applying it to my doors and roof to make it even quiter in the cab than it already is.
Old 11-13-2008, 05:30 PM #9
RickC's Avatar
RickC RickC is offline
RickC is on a distinguished road
RickC's Avatar
There is a user goes by Mustang67408 on the tundrasolutions.com site that sent me a pdf file that showed how to remove the panels on my mothers Avalon. You could try him, he's a toyota mechanic and was very helpful to me in replacing the door actuators.
RickC
2003 Toyota 4runner Sport V6 4x4, Daystar 2.5/1.5, Enkei ST6 18x8.5, Toyo Open Country AT2 285/60/18, Scion FRS Touchscreen head unit with NAV and backup camera, LEDBARZ 41" light bar.
RickC is offline   Reply With QuoteReply With Quote
Old 11-14-2008, 05:22 PM #10
i am planning on doing a writeup on removing the 3rd gens tonight.... i did both front and back drivers side doors yesterday.... and now i will shouw you the tips and tricks of this tonight.... maybe tomorrrow ill have the writeup done... let me know if you still need it?
Old 11-14-2008, 08:21 PM #11
yep i still need it my stereo and speakers are not in stock so i canceled the order because it took them a week just to tell me they did not have any of it
Old 09-09-2009, 06:21 PM #12
piperoo's Avatar
piperoo piperoo is offline
piperoo is an unknown quantity at this point
piperoo's Avatar
Did you ever do a write up? I looked, but couldn't find one. Thanks!
piperoo is offline   Reply With QuoteReply With Quote
Old 09-09-2009, 06:27 PM #13
Elton H's Avatar
Elton H Elton H is offline
Elton H is on a distinguished road
Elton H's Avatar
dont forget to pop the arm rest off and remove the 2 screws
98 4runner sr5 3.4L 5spd 4x4 e-locker sold 10/2/11
07 tundra 5.7L 4x4 limited dc was my moms r.i.p 3/19/11
Oregon Toyota Owners Club
Elton H is offline   Reply With QuoteReply With Quote
Old 09-09-2009, 08:26 PM #14
piperoo's Avatar
piperoo's Avatar
I got the front right door off....had a few screws left over when I put it back on.
Old 09-10-2009, 05:53 AM #15
ChildrenOfBodom's Avatar
ChildrenOfBodom ChildrenOfBodom is offline
Moderator
Real Name: James
ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light
Moderator
Real Name: James
Originally Posted by bootown View Post
Two big gold ones were hidden under the armrest piece you pulled off.
One holds the interior door handle one.
That's actually all I can think of.
yup, that and a bunch of lame ass clips.
really, its lame if you can't figure it out yourself, its so easy.
IG: @jimharb | YouTube | '99 Limited 2WD |
'99 4Runner - 2.7L 3RZ-FE - TRD S/C - 4WD Conversion + R150F 5-Speed Swap - Imperial Jade Mica on Oak
'87 4Runner Turbo - 2.4L 22R-TE - CT-26 Supra Turbo - W56 5-Speed Swap - Red on Red
'90 4Runner 2-Door - 3.0L 3VZ-E - Auto to R150F 5-Speed Swap - Red on Gray
'94 Supra Turbo Targa - 3.0L 2JZ-GTE - Marlin Crawler R154 - Imperial Jade Mica on Black
'89 Supra Turbo Targa - 3.0L 7M-GTE - Marlin Crawler R154 - White Package on Blue
'89 Pickup DLX 2WD - 2.4L 22R-E - W55 5-Speed - White on Blue
ChildrenOfBodom is offline   Reply With QuoteReply With Quote
