12-03-2008, 07:50 PM
Where is the Trac/VSC Wire connector at??
Ok so i have a 2002 limited and me and a friend wanted to have some fun in some snow in a abandoned parking lot but of course the traction control prevented the fun. I wanted to know where the plug is so i can unplug it at the lot do a few donuts and such then plug it back in for the road.
Also is there a procedure in doing this? Does the truck have to be off while unplugging it.
And when you go to plug it back in does the truck have to be off.
Any Steps??
Pics would also help too
Thanksss
2002 Limited v6 4wd
HID 10000k < no projections yet
Driving Fog lights
Full Polk Audio system
http://i38.tinypic.com/2wrqo95.jpg
12-03-2008, 09:37 PM
12-03-2008, 09:56 PM
So all i have to do is unplug that connector and it will turn off the vsc and trac??
I dont need the whole set up of the switch.
I wanna do this
http://www.youtube.com/watch?v=3G_Kq3daTgM
2002 Limited v6 4wd
Driving Fog lights
12-03-2008, 10:13 PM
Dude, read the whole thing. No, you can't just unplug the connector.
12-03-2008, 11:01 PM
P Nut, actually YES you can just unplug the pressure sensor connector to disable trac/vsc/abs. This is the "poor man's" version of the andymod .
Lee use to do that all time when he went wheelin'. He'd pull off the road, get out of the vehicle, pop the hood, pull the plug and then head out on the trail. When finished, he'd have to get back out, pop the hood again and reinstall the connector.
The offical andymod includes installing the switch inline so you don't have to get in and out of your vehicle anytime you want to disable the systems. Lee eventually did the official andymod and installed the switch. (He got tired of unplugging and plugging it back in all the time.)
Mitchc4216, as stated in the write up above, it's real easy to install a switch inline to disable the systems. However, yes you can just unplug the pressure sensor connector at the MC and you're good to go. But if you're like most, you'll get tired of doing it this way and will soon want the in cab switch.
Otherwise, go buy a 1st gen and play in the snow
2002 4Runner Sport 4WD
Headlight Adjustment
"Live life w/o Limits. Your imagination is not limited by time or distance, by logic or by scarcity. You can fill your imagination with whatever you choose."
12-04-2008, 06:37 PM
Thanks RockSlide. I have still yet tried unplugging it, I will probably attempt it tomorrow night. So does the vehicle have to be off to unplug the connector? I think it would be the safest thing to do?
2002 Limited v6 4wd
Driving Fog lights
12-04-2008, 11:57 PM
From what I remember, you can unplug the connector and plug it back in all while the vehicle is running. I flip my switch to disable the systems all the time with the vehicle running. However, don't just take my word for it...read it for yourself in the below thread.
Granted it's a good hour's worth of reading (22 pgs to be exact), but if you want to know how the "andymod" came to fruition and who created it, check it out here:
http://www.yotatech.com/f2/vsc-trac-...closer-45793/.
Many tests were done to achieve the final goal of the andymod. Your question of unplugging the connector with the engine running is discussed within that thread.
12-05-2008, 01:44 AM
I unplug that fuse in the engine bay all the time. Make sure it's the green one though. I turn my engine off just to be safe, although I doubt it really makes a difference.
'02 Limited 4WD
Stuff:OME 3"|ARB Tacoma|Light Racing UCA's|Savage KO sliders|285/75 Terra Grapplers|TRD catback|TRD wires|Brembo'd|VVME 4300K HID|LightForce 170|Exterior LEDs||Inside: Infinity Comps/Kicker/Nuvi625WT|Uniden 520XL|15% tint|Full LED swap|Backup camera
Pending Install:LC80 wheels,OME 883 and LC 8 wraps,panhard drop
12-05-2008, 03:05 PM
My bad, I was getting this and the DRL confused.
12-05-2008, 03:36 PM
Haha, no problem
12-07-2008, 11:38 AM
Well yesterday I went to any old parking lot after if snowed a bit and covered the ground. Jumped outta the truck popped the hood unplugged the wire got back in and saw that the ABS/Trac/Vsc lights where on when the truck was running which meant of course they are off.
Lets just say there was no snow left in the lot after i left :clap:
2002 Limited v6 4wd
Driving Fog lights
12-07-2008, 04:58 PM
Congratulations...fun aint it
12-07-2008, 05:06 PM
haha Oh yea it is.
RockSlide, I was looking through your 4runner profile and i am very impressed with your 4runner. Its a very nice vehicle and your attention to detail shows it. But i have a few questions. I saw you bought the sound dampening tape and covered all of the floor and bare metal area's. How much did that cost? How much did you use? And how long did it take? I would love to do that to my 4runner.
2002 Limited v6 4wd
Driving Fog lights
12-08-2008, 10:48 AM
Thanks.
I purchased 5 rolls @ $19.99ea ($100 total) and used 4 1/2 rolls for the front and rear of the cab, the cargo area and the tailgate. Stuff works great too. I still need to find time to purchase some more and do my doors and roof.
For reference, I used Part Number: 9640T2 in the 6" roll at McCaster-Carr: http://www.mcmaster.com/. (Just do a seach and you'll find it.) It has a very strong adhesive on one side and a reflective aluminum surface on the other.
Time wise, it took me a full 3 day weekend and roughly 4 weeknights to do it remove all the interior, lay the sound deadening and reinstall everything. (I drove around with just a driver's seat installed for 3 of those days ). I probably could have done the install quicker, but I took my time doing it.
