Old 12-04-2021, 01:16 AM #166
Romeo1's Avatar
Romeo1 Romeo1 is offline
Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice
Romeo1's Avatar
There’s a spec for the trans pressure cable. Protector protrudes so many mm. It’s not much.
You could probably just adjust it and not replace it. TPS is on the throttle body itself. I’ve done that for over a year now since the rubber cushion was busted.
That said, I do have a new one, only because I’ve changed everything else on this 4runner so why stop now…
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
Romeo1 is offline   Reply With QuoteReply With Quote
Old 12-06-2021, 06:11 PM #167
bmason8159 bmason8159 is offline
bmason8159 is on a distinguished road
Did this today with the truck running as to make sure not to pull the cable too much. Works like a charm.
bmason8159 is offline   Reply With QuoteReply With Quote
Old 12-07-2021, 05:42 PM #168
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
There's only two reasons to replace the cable outright:
1. There's damage to the cable sheathing and the cable binds up and won't open or close the throttle.
2. The cable has stretched to the point that there is no thread left to tighten the cable.
I had 2. happen on mine so bought a new cable. Throttle feel is relatively unchanged, maybe a tad bit less resistance but the slack was no longer an issue.
326WHP 347TQ
Old 12-07-2021, 05:47 PM #169
cl4Rk's Avatar
cl4Rk cl4Rk is offline
cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold
cl4Rk's Avatar
That's my understanding as well. And even if you've got a little cable stretch, you can eliminate slack by replacing/repairing (or even extending) that little rubber grommet on the pedal-end of the throttle cable. Throttle response is unchanged. Just no play:
- https://www.toyota-4runner.org/2936430-post153.html
- https://www.toyota-4runner.org/3693552-post33106.html
2000 SR-5 V6 4x4 Auto
"Ol' Ruby" - build thread
@Y2K_4X4
cl4Rk is offline   Reply With QuoteReply With Quote
Old 12-07-2021, 06:24 PM #170
Option01 Option01 is offline
Option01 is on a distinguished road
Nice, thank you! Good to know that I can use that rubber hose trick if the throttle cable stretches out more (I already used up most of the adjustment threading).
1999 SR5 V6/Auto 4WD
4.88 Gears, Front/Rear E-Lockers
1" Body Lift, 2" Suspension Lift, 285/75 R16 Tires
Option01 is offline   Reply With QuoteReply With Quote
3.slow throttle response tip 88T4RE Classic T4Rs 2 01-04-2010 01:45 AM
No throttle response after head job Grimsta Problems & Warranty Issues 2 01-24-2008 12:29 PM
No throttle response after head job Grimsta Classic T4Rs 3 01-23-2008 06:07 PM
poor throttle response when cold 1990runner Classic T4Rs 0 12-09-2004 08:17 PM
Throttle Icing Thai Maintenance/Detailing 0 02-27-2003 05:44 PM
