06-16-2011, 08:51 PM
#61
Originally Posted by HI_LIFE808
Loosen up the left nut and tighten the right one. This should take the slack out of the line... This should be mod/maintenance item number one on the DIY list. Did it to my runner and it is like night and day!
Edit: noticed that you have an older year 4runner. I have a 01' that has a different cable set up but it should be the same in removing the slack, loosen then tighten.
Ohh so loosen up the left nut and tighten the right one... Now I understand. I'm probably gonna start doing that soon (Saturday)
-1998 T4R Limited in Sunfire Red Pearl | 3.4L | 4WD | 99 tall coils with OME shocks | Deckplate Mod |
-2005 Toyota Tundra in Spectra Blue Mica | 4.7L | 4WD | Powerstop slotted and drilled rotors | K&N Series 77 CAI | 17" Gunmetal Tundra/Sequoia wheels wrapped in 265/70/17 BFGoodrich All-Terrain T/A KO |
06-17-2011, 11:51 AM
#62
Checked mine, was loose, tightened it and it idled too high, loosened it to get the 750 idle and it's loose again. Pedal seems wiggly now, too.
2001 SR5 4X4, V6, 3.4L
06-17-2011, 06:54 PM
#63
Alright just got done fixing my TB and d*mn it's made a HUGE difference in the throttle response! Loving it so far.
06-17-2011, 10:26 PM
#64
Best part about it is that it's free!
06-17-2011, 10:32 PM
#65
Real Name: Robert
Real Name: Robert
Just did this myself and I definitely could tell a difference. Didn't think that it would make such an improvement.
My 4runner Build Thread 2000 Limited 4runner SOLD
My Tundra Build Thread 2006 Double Cab Tundra SOLD
My Humpty Dumpty 4runner Build Thread 1999 Highlander 4runner
06-18-2011, 09:44 AM
#66
Yup.
06-19-2011, 02:31 PM
#67
My 2000 runner idles just over 1,000 RPM (cold start). I assume that's too high? I haven't adjusted my cables yet, just took note of pedal response and idle RPM. Going to check my cables now.
06-19-2011, 05:58 PM
#68
Checked it out again. Actually it idles cold at 1500 RPM, but once warmed up sits idle at about 500 rpm. Will tighten the cable to bring it to ~700 RPM.
07-12-2011, 11:15 PM
#69
Real Name: Instagram: briansd_97r
I regret having messed with my throttle after reading this thread.
A few weeks back I adjusted all the cables and set the idle to 1000, pulled the slack out of the other cables and after driving it a few weeks something just seemed wrong.
It is fixed now but only because I had a pro reset the cables to factory specs. Afterwards I was told that what happens is actually that the pedal gets bent over time, not that the cables stretch out.
The cables just look stretched out because they are old. The solution for the "loose pedal" is to bend the pedal back, not mess with the wires because doing so confuses the Toyota computer.
This is what I was told anyways. All I know is that now that I got it looked at, it is idling and shifting better.
Those he commands move only in command, Nothing in love. Now does he feel his title, Hang loose about him, like a giant’s robe, Upon a dwarfish treasonous thief.
07-12-2011, 11:40 PM
#70
You're only supposed to tighten the cables enough to get the slack out. Not pull the throttle mechanism so much your idle increases. The computer is in charge of the idle speed.
Why did you want it at 1000rpm?
1996 SR5 4Runner V6 4WD Auto
Toytec Ultimate w/ OME 890's plus 1.5" daystar spacer
60028 OME shocks, Goodyear Duratracs 265/75 -16
B&M 70268 with Magnefine filter, 199mm TBU
236K miles
07-13-2011, 03:23 AM
#71
I did only tighten them enough to "get the slack out" but since this method is kind of like "eyeballing it" it didn't work out very well for me.
07-13-2011, 03:32 AM
#72
i had the opposite happen. i tightened them all the way and there is still slack! and suggestions as to what i should do? did notice better response but wondering it there is a way to get all the slack off. with it tighten all the way i can still take the cables off the pulleys with my finger. trust me when i say they were really loose before i did this
work in progress
02-18-2012, 12:35 AM
#73
Similar thing here. I was able to tighten them up today and it help some but there is still slack, mainly in the cruise control cable. However it is at the end of it's threads on the nut. Is there anything else I can do to tighten it up even more?
'14 Trail Super White|Nav|Tint|EnTune| Toytec BOSS Kit|Konig Countersteer Type X Matte Bronze 17x8"|Cooper Discoverer ST Maxx 255/80/17|SPC Light Racing UCA's|WeatherTech| 4300K HID's|Valentine 1|White Knuckle Offroad Sliders|GOBI Stealth
Build & Photo Thread
02-18-2012, 01:36 AM
#74
Skip this supposed mod. It is not worth the trouble.
02-18-2012, 01:46 AM
#75
To late
work in progress
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
