There’s a spec for the trans pressure cable. Protector protrudes so many mm. It’s not much.
You could probably just adjust it and not replace it. TPS is on the throttle body itself. I’ve done that for over a year now since the rubber cushion was busted.
That said, I do have a new one, only because I’ve changed everything else on this 4runner so why stop now…
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
