Originally posted by scotts97T4Rltd
at that mileage, i would at least pull the plugs and see what they look like, if they are white, your truck is running lean. i would probably pull the injectors, and send them off to be cleaned. BTW, have you checked the simple stuff, like cleaning your MAF, and maybe testing the TPS to see if it is within range? How about the 02 sensor? There are lots of things that it could be without actually throwing a code.
Haven't tried the "simple stuff" like this. I will and let you know, this is the type help I was looking for. Thanks much!!!
Are there any procedures listed somewhere around here to clean the MAF or how to test the TPS to see what the range is? 02 sensor is just a change it out, there isn't any "test" as such is there?
