Old 01-29-2009, 12:44 AM #1
HNTMUP HNTMUP is offline
HNTMUP is an unknown quantity at this point
Slip Indicator Light
Let me preface my questions by saying that I am relatively inexperienced when it comes to 4wd. I have driven several Explorers, Outbacks and Audi's, all of which are really automatic AWD. This past August I bought a 4WD 2002 SR5 that I enjou more than any other vehicle I have owned. I took out this afternoon into some deep snow and there were times when the rear end lost traction and the tires started to spin. The "Slip Indicaror Light" came on and the engine dropped power. This happened several times.
I am assuming that the reason the engine slows is to facilitate the tires regaining traction but it seems strange than when I try to accellerate nothing happens until I take my foot off the gas and the tires bite in. My concern is there are times (like when I am in deep snow) that I don't want my truck to lose momentum.
What am I missing or not doing right or is there a mechanical problem that I need to have checked-out?
Thanks
HNTMUP is offline   Reply With QuoteReply With Quote
Old 01-29-2009, 09:12 AM #2
pat161's Avatar
pat161 pat161 is offline
pat161 is on a distinguished road
pat161's Avatar
What you are experiencing is the VSC, or vehicle skid control, system kicking in and reducing engine power. All you need to do is press the center diff lock switch to the left of your steering wheel. When you lock the center diff two things happen, first you now have a traditional 4wd system and should not be operating on dry pavement, second VSC is deactivated until you unlock the center. You will notice on your dash when you push the 4wd button the 4 green wheels light up, when you hit the center diff lock an orange light will come on in the middle and the VSC Off light comes on. If there is a bit of snow here and there or its just a bit slippery just use 4wd, if the snow is deep or you are doing real off roading lock the center.
pat161 is offline   Reply With QuoteReply With Quote
Old 01-29-2009, 10:27 AM #3
Pat,
Thanks for explaining that so clearly. That clears things up. I was driving in snow that was 10" - 20" deep. I don't even like to have the vehicle in 4WD on the road.
Thanks again.
Basic article about DIFFERENTIALS, LSD, LOCKERS... Thai Off-Roading 13 09-01-2017 11:46 AM
Drive shaft noise or U joint noise (LEXUS 4/06 TSB page 18) aka Driveshaft thump/bump rorad Problems & Warranty Issues 764 08-16-2016 08:49 AM
Limited Slip question rx900 4th Gen T4Rs 3 12-21-2015 06:16 PM
Can you turn of anti slip feature? Master Yoder 3rd gen T4Rs 15 01-10-2010 11:41 AM
Question r/e diff. slip when backing downhill then starting forward uphill and 4wd... jcage89 4th Gen T4Rs 1 09-20-2006 04:43 PM
